Radiator hose looks warped and rubbing against engine...
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Northstar Engines and System Technical Discussion Discussion, Radiator hose looks warped and rubbing against engine... in Cadillac Engine Discussion; Is this normal? The top radiotor hose looks a little warped and it is making contact with the engine. It ...
    powerglide's Avatar
    powerglide is offline Cadillac Owners Connoisseur
    Sep 2003
    Hermosa Beach, CA
    2,721
    QuestionRadiator hose looks warped and rubbing against engine...
    Is this normal?
    The top radiotor hose looks a little warped and it is making contact with the engine. It looks like a little chaffing is occuring where its contacting.
    I was gonna take a piece of plastic tie and secure the hose against the frame or the plastic cover that runs along the top of the front engine bay.
    Just curious, because I am finally gonna get to doing a cololant change here in a few days and wondering if this needs to be replaced too.
    Thanks (98 deville, 91K miles, never has overheated)
    69
    82,396
    Re: Radiator hose looks warped and rubbing against engine...
    Mine was like that too. I just wrapped it with duct tape at the contact point. I noticed my daughters '99 SLS has a retainer to hold the hose in place away from the engine and keep it tucked up under the radiator cover.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    My '02 SLS has the radiator cover, that holds the top radiator hose. Does the Deville's not have this? If it does, just pop it back behind there.
    Don
    69
    82,396
    '97 doesn't.
    powerglide's Avatar
    Sep 2003
    Hermosa Beach, CA
    2,721
    Quote Originally Posted by Dadillac
    Don
    Doesn't look like the 98 has one either.
    I dont want to put a point load on the hose by using a zip tie but dont want to use duct tape either.....I've got to figure something out.
    Lemme know if anyone has a slick fix.
    Thanx
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    Black duct tape!
    powerglide's Avatar
    Sep 2003
    Hermosa Beach, CA
    2,721
    Yeah good idea....but the concern is that the hose will continue to rub, eventually through the duct tape. It'll be a bandaid of a fix.
    1996deVille is offline Cadillac Owners Member
    Feb 2005
    74
    Find a piece of old rad hose and cut it at about 3" or so. Slice one side down the middle. Slip it over the hose where it rubs and cable tie (black) in place. The "rub" will occur on the cut 3" section.
    Good luck!
    powerglide's Avatar
    Sep 2003
    Hermosa Beach, CA
    2,721
    Thats the best idea so far! I was thinkin along those lines but dont have an old rad hose....so I was thinking a piece of leather/cloth/toilet-paper-inner-roll.....
    I think a thick cloth or something would work.
    Thanks!
    69
    82,396
    FWIW. my tape hasn't worn through in several years. I once did the same thing on a 501 but I used aluminum tape. That never wore through either.
    Spyder's Avatar
    May 2004
    Sonoma Co, CA
    34
    5,688
    Yea, I don't see how it'd rub through a good quality tape but not through a piece of cloth or toilet paper inner roll... but I do like the old rad hose idear...I'd go with the black duct tape though...not quite as big and noticeable.
    outlaw1369 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado 1996 Sedan Deville
    Aug 2004
    New York
    57
    Buy a new hose ($10-$12) at Pepboys, Autozone, etc... and use the old one for the sleeve. It's cheap insurance and your existing hose has already started to wear at the contact point.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    No old radiator hose...????.....
    Time for some dumpster diving behind an autosupply store or nearby garage. EVERYONE should have a piece of old radiator hose around for making bandaids and abrasion shields.
    Keep in mind that if the hose hasn't worn thru or damaged itself in 91K/8 years it is probably OK.....
  16. #14
    powerglide's Avatar
    Sep 2003
    Hermosa Beach, CA
    2,721
    No hose.....I;ve been moving from every 9 months-1 year for the last few years....you tend to shed lots of stuff....
    Is the new hose really that cheap? Don't you need special part (hose molded for my car)?
    Its cheap I guess its not a big deal to replace it but if its not necessary then I'd rather spend it on something else.
  17. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,315
    If you want it to look aircrafty, go to your industrial electrical supply store and get big spiral wrap, a ty-wrap anchor and a big ty-wrap. the spiral wrap to protect the hose and the ty-wrap and anchor to nail it in place and prevent future trouble. Split radiator hose is Sooooo ghetto!
  18. Remove Advertisements
