loose power steering rack
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, loose power steering rack in Cadillac Engine Discussion; i noticed the other day my seville was leaking something pretty rapidly, so i pulled it up on the ramps ...
    cart69's Avatar
    cart69 is offline Cadillac Owners Fanatic
    Automobile(s): 96STS engine only!! only thing left from my 96 after divorce
    Dec 2004
    Illinois
    37
    150
    i noticed the other day my seville was leaking something pretty rapidly, so i pulled it up on the ramps and it was power steering fluid, i found one of the two lines that attach to the rack was loose, so i tightened it and had the car started and it was fine, ,then i told my brother in law to turn the wheels slightly back and forth, when he did the whole rack assembly moved about 1 to 2 inches!!! i found that one of the welded nuts in the crossmember had broken and was loose to the whole rack could slide back and forth through the other mount!! anyone heard or seen this before, was something new to me!!! have to creak out the welder and fix it this weekend!!!
    also noticed my intake valley is now got a nice pond of power steering fluid in it again after i cleaned it out a few months before so i assume a leak is there somewhere too!!!
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: loose power steering rack
    You'd probably get better responses and probably an answer in the suspension or model-specific forums.
    Good luck...
    Mike
    cart69's Avatar
    Dec 2004
    Illinois
    37
    150
    i tried to pm a moderator and it wont let me, do any of you know how to move this thread to the seville forum???? thanx in advance
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    I'd just do a copy and paste and start a new one.
  7. Remove Advertisements
