Head gaskets and Time-Serts
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, Head gaskets and Time-Serts in Cadillac Engine Discussion; edited.jpg On my second Northstar head gasket job. It's going a lot easier this time around; I have all the ...
    NorthstarRecovery is offline Cadillac Owners Member
    Automobile(s): 2000 deville
    May 2013
    27
    13
    On my second Northstar head gasket job. It's going a lot easier this time around; I have all the tools and the know how.
    I just wanted to know if anyone knew of a good (as in cheap) place to get the 11x1.5MM Time-Serts? Every place I've found ran about $100 for all 20.
    Also, I used Victor Reinz gaskets on the last one and they seemed to be exceptional gaskets. I only did this because I've heard Fel-Pro is crap...maybe that was just whispers in the wind, I don't know. RockAuto carries both brands and the head bolts.
    What do you guys think?
    68
    81,902
    Re: Head gaskets and Time-Serts
    Your only options are Timesert, Norm's NS300L inserts or studs from Northstar performance or Carroll Custom Cadillac, not of which are "cheap", but $100 for 20 inserts doesn't sound all that expensive.
    May 2013
    27
    13
    Yeah, only Time-Sert's inserts should be used with the Time-Sert kit. I know that. I was speaking in terms of maybe someone had some they wanted to sell, knew of the best website to buy them from, whatever.
    My biggest question is: are Fel-Pro gaskets really of bad quality??
    I have a third question now, too. I ran my codes before butchering the car...
    B0159 Was missing the sensor attached to hood-latch assembly. Replaced it.
    B0189 Solar load sensor #2 circuit range - not sure what this one means. Know it has to do with the lights, and possibly the domed sensor on the dash pad??
    B0429 Temperature Control #3 Rear Circuit Range/Performance - Probably ignore this for now until I have the car back together and check to see if the temperature coming into the rear is any different than the front.
    B2646 Ambient light sensor circuit range - No clue what this one's about.
    RIM< C0660 - Level Control Exhaust Valve Circuit Malfunction - I replaced the air pump because I had another one. No idea if that's what it was, or if the one I replaced it with was even good. The one I replaced it with only had 90k, though.
    SDM< B0026 - Left Front/Driver Frontal Deployment Loop Single Stage Open - Air bag crap...I know that much. Maybe just a loose wire? Also heard of wires getting jerked around in the steering column on these?
    TTM< B2860 - Telescope Position Sensor Range - It's a DHS, and has the electronic adjustment for the tilt-wheel. It goes so far forward it makes a clanking noise. I don't know how to fix this, though.
    One other issue I have is that the whole dog-house (bumper cover, fenders, hood, grill and all) have been replaced with a darker red color and the sensor that involved the HUD that's in the grill is missing. So the HUD doesn't work because of this. I believe my car's color is "Medium Red". I don't know where to find the paint code, or where to buy the paint, but I definitely will be getting it sprayed to match the car. Any ideas there would help.
    Once all of this is done this car will be off-the-lot condition with 120k.
    Any input, constructive criticism, or guidance would be very greatly appreciated.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,870
    B 0189 - solar load sensor - one of the HVAC control inputs. "Sun heat sensor". One or two reddish domes on the dash top.
    B 2646 - ambient light sensor - little greenish disc down in the dash vent next to the left sun load sensor - ambient sensor sets the "Headlamps suggested" message and controls Twilight Sentinel headlamp operation. They tend to get pushed and fall down into the dash area. No fun to replace.
    Paint code on the sticker under the spare tire cover. www.paintscratch.com
    68
    81,902
    B0429 Temperature Control #3 Rear Circuit Range/Performance is very common on these cars and I have been told that it does not take much to set the DTC. Unless you have passengers in the back seat a lot and the control is way off, I wouldn't worry about it.
    mjbrome is offline Cadillac Owners Member
    Automobile(s): 2001 Deville Base
    Oct 2013
    St. Cloud, MN
    19
    Felpro is a good company. They came up with a good solution to the plenum issues. Carroll's custom Cadillacs swears by them. That's what I bought after hearing that's all he used. Figured after all, he does it for a living and claims one never came back.
    May 2013
    27
    13
    You two are more help than I think you may know. I've lurked around on this forum and the other caddy forum for a good while now figuring stuff out and Googling things when I took on my first head gasket job. It's been a learning experience. And I've loved almost every minute of it, so I decided to start posting and hopefully that'll get me where I'm going quicker and enable me to be able to help others in the near future.
    One last thing I had forgotten to add earlier...This DHS has the HUD night vision option. Which makes it very cool. But...the catch is...the dog house was replaced with one without it so the camera deal in the grill is gone. I don't know how in the world I would find this without buying it new (which I'm assuming is pricey), I hardly ever see DHS's at the junkyards let alone ones with the option. I don't know what it's called, or how to even search online for it. But it sure would be cool if it worked.
    Thanks guys.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    May 2013
    27
    13
    ouch.
    68
    81,902
    You really didn't want night vision anyway, now did you.
    May 2013
    27
    13
    Not for that price.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Our local fastenal dealer has timeserts. $3 each.
    May 2013
    27
    13
    That's odd; I checked Fastenal. They told me they didn't have them. But that's about what they cost from MechanicsToolsAndBits is 3.30 - some/each. I already had 2, got 18 of them + the four dowels for 86 - some dollars with free overnight shipping..not bad. The dowels were about $5/each.
    Oh...and I got all the necessary gaskets; Victor Head gaskets, Fel-Pro bolts, Fel-Pro exhaust manifold gaskets, two Fel-Pro upper water pump gaskets, Fel-Pro camshaft seal all shipped for $157.
    So...provided you already have the time sert tool...a head gasket job only costs $247 lol.
  16. #14
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    I'd reuse the factory exhaust manifold gaskets, just clean them up.
    Spray rust penetrant on them, lightly scrub them with a grey scotchbrite pad, spray brake cleaner on them and bolt them back on.
    I looked at the exhaust manifold gaskets in the felpro kit and said no way.
  17. #15
    Aug 2007
    mpls mn
    2,528
    Perhaps my fastenal dealer no longer has them. At least u got some. Good.
  18. Remove Advertisements
