How did this happen?
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, How did this happen? in Cadillac Engine Discussion; On my 98 Deville, I had the water pump replaced at the dealer w/gmpp in march 05. I also had ...
    JAZZ392's Avatar
    JAZZ392 is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade, 1998 Deville
    May 2004
    Queens, N.Y.
    64
    27
    On my 98 Deville, I had the water pump replaced at the dealer w/gmpp in march 05. I also had the blower moter replace in early april 05. After replacing the pump I noticed that the coolant temp was running cold and very little if any heat while driving. So on saturday I decided to replace the thermostat which was not replaced. After removing it I found a bolt stuck in the thermostat which was keeping it open.. Any ideas on how/when this could have happened ?.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: How did this happen?
    Maybe the N* engine forum may have more response?
    69
    82,177
    Sloppy workmanship at the dealer. The question now is, where did that bolt come from? This is just a hunch and I don't know if it is possible but perhaps it somehow was dropped in the pump housing and the pump flushed it to the choke point (thermostat).
    powerglide's Avatar
    powerglide is offline Cadillac Owners Connoisseur
    Sep 2003
    Hermosa Beach, CA
    2,721
    holy cow, thats disturbing.....
    I have 98 deville too, 93000 miles on it. (how many miles on yours?)
    How'd you know they water pump and blower motor needed replacing, id the sieze up?
    (just wondering if I need to do these repairs soon)
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    moving to northstar , perhaps your not alone ..
    JAZZ392's Avatar
    May 2004
    Queens, N.Y.
    64
    27
    Quote Originally Posted by powerglide
    Mine has 62000 miles. With the water pump the car was overheating. The blower motor just was not blowing at all.
    The service dept did not replace the thermostat under GMPP ,because it was not defective. They did flush the coolant system. After watching the cooltant temp and with the lack of heat I searched the board here and found that the thermostat could be the problem (which it was)
  9. Remove Advertisements
