97eldo Need Help
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 97eldo Need Help in Cadillac Engine Discussion; HAVE 97 ELDO WITH 47,000 MILES ON IT. ENGINE GOT SLOWER AND SLOWER TO START WITH FIRST BACKFIRE, THEN RAN ...
    97ELDO1 is offline Cadillac Owners Member
    Apr 2005
    7
    97eldo Need Help
    HAVE 97 ELDO WITH 47,000 MILES ON IT. ENGINE GOT SLOWER AND SLOWER TO START WITH FIRST BACKFIRE, THEN RAN BEAUTIFUL. HAD BIG
    BACKFIRE AND NOW ENGINE WILL NOT START BUT BACKFIRES. COULD THIS BE A BAD CRANKSHAFT POSITION SENSOR. APPRECIATE ANY HELP ON THIS PROBLEM.
    Eldo1953's Avatar
    Eldo1953 is offline Cadillac Owners Enthusiast
    Automobile(s): 53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
    Feb 2003
    Winnipeg, MB
    756
    Re: 97eldo Need Help
    You will probably get a better answer in the N* forum...
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Do you have a Service Engine light? Have you looked for codes? Anything else colorful about the history of the car?
    Mike
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Check the fuel pressure regulator. Pull the vacuum hose off the regulator (that small canister shaped device on the fuel rail) and turn on the key to energize the fuel pump. Watch the vacuum nipple for any sign of fuel seeping from it...??
    Are you sure you have fuel pressure. You might put a gauge on the shraeder valve fitting on the fuel rail and check the fuel pressure while cranking.
  7. Remove Advertisements
