Engine seems to misfire a bit when it's cold or damp out
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Engine seems to misfire a bit when it's cold or damp out in Cadillac Engine Discussion; After I changed my plugs/wires I noticed that the engine tends to "sneeze" when it's damp out, like I can ...
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    After I changed my plugs/wires I noticed that the engine tends to "sneeze" when it's damp out, like I can feel a minor jerk and my engine rpm goes down a little bit(25 to 50 rpm), I think this is a electrical connection problem since it doesn't do this when it's warm out, so what could cause this? My wires came with those silicone looking stuff to prime on the plugs but I didn't use it.
    powerglide's Avatar
    powerglide is offline Cadillac Owners Connoisseur
    Sep 2003
    Hermosa Beach, CA
    2,721
    Re: Engine seems to misfire a bit when it's cold or damp out
    Does it happen only at idle or even at speed?
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Quote Originally Posted by weister42
    You should apply the grease. It keeps the boots from welding to the plugs so you don't ruin them next time you pull them off.
    Dampness usually encourages "leaking" wires to do their thing. If you look under the hood at night on a damp night, bad wires can be seen arcing to metal or on another. Some guys mix saltwater and mist their wires if they suspect this condition.
    If this problem began right after you replaced the wires, check them out to be sure they are not defective.
