Changing the water pump "Belt?
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By N*Caddy
Northstar Engines and System Technical Discussion Discussion, Changing the water pump "Belt? in Cadillac Engine Discussion; What do I need to do to change the water pump "belt" on a 98 DeVille, Northstar? It looks to ...
    lonleyboy54 is offline Cadillac Owners Member
    Automobile(s): 98 DeVille
    Aug 2013
    63
    1
    What do I need to do to change the water pump "belt" on a 98 DeVille, Northstar? It looks to me like I have to take the water pump, "and the housing off? Is there an easier way, "just" to change the "belt"?? Please help!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Re: Changing the water pump "Belt?
    Look in Cadillac Tech Tips and in my albums - simple job. Click my username, open the profile, left column, 2 albums, 6 pages of Northstar stuff - yours is earlier, but the water pump drive is the same.
    Remove the water pump belt drive shroud - two 10mm nuts, a 10mm bolt. Use either an adjustable wrench on the tensioner arm lug cast into the arm or a 1/4" drive socket tip in the square hole in the tensioner arm - lever the arm so as to remove tension, slip the belt off the pulley. It will be MUCH easier if you remove the tensioner assembly, too - the two long studs that held the first two nuts. If that tensioner pulley is not slippery-viscous-smooth and quiet, change it, too.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    No, just remove the tensioner. 10mm deep socket for the bolts after removing the belt guard. Use a 13 mm wrench on the tensioner pulley bolt to rotate it up to release tension and remove/reinstall the new belt.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Yeha is a very simple solution, turn the belt on a side to get it out of the WP pulley, can't be more simple.
    94CaddyConcours likes this.
  7. Remove Advertisements
