High Mileage Northstar Thread: Who can beat me? - Page 12
Page 12 of 30 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
Results 166 to 180 of 449
Like Tree149Likes
Northstar Engines and System Technical Discussion Discussion, High Mileage Northstar Thread: Who can beat me? in Cadillac Engine Discussion; Got my Caddy about 2 months ago with 135,000 miles on it. I now have 137,000 miles on it lol ...
  1. #166
    Kcguy is offline Cadillac Owners Member
    Automobile(s): (formerly) 2001 Cadillac Deville (Current) 2007 DTS
    Mar 2009
    Kansas City
    34
    40
    Re: High Mileage Northstar Thread: Who can beat me?
    Got my Caddy about 2 months ago with 135,000 miles on it. I now have 137,000 miles on it lol and have already had 2 problems, not really engine related though. Transmission line busted and Starter went out, but still kinda discouraging after owning the car only 8 weeks. The repair shops have been in possesion of the car longer then me so far hehe, I really hope that will change.
  2. #167
    bbrewer5 is offline Cadillac Owners Member
    Automobile(s): 97 Eldorado ETC
    Nov 2007
    Middletown, OH
    30
    49
    I have a 97 Eldo ETC with 124k on it. Its been well maintained but it has been driven HARD HARD HARD. Somewhere around 200-300 launches EASY. There hasn't been many times that its been driven that it hasn't been WOT'ed at least once since about 60K miles (only when tight on gas money). Engine still runs the same as it did at 60K but the trans is on its way out the door. slips and whines and doesn't like to shift.
  3. #168
    Mizugori is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS
    May 2009
    NY
    30
    54
    I'm looking at a 1996 Deville, has 125k miles, the guys says it needs a lower ball joint on the front left and a hub bearing on the same side. And that to have both replaced would cost about $500. Is this accurate? Would I get that done at a dealership, or a independent place?
    thanks!
  5. #169
    AlBundy's Avatar
    AlBundy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado Sport Coupe
    Jul 2005
    Chicago
    4,992
    I'm at 73500 miles. Trans sensor gone but I can deal with it.
  6. #170
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 Honda Accord EX V6. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    26
    3,718
    I'm now closing in on 71k miles on my '00 STS and the only real engine problem I suffered was the all too common crankshaft position sensors, which I got fixed back in January. Otherwise my motor has been great; it had the HG's replaced, Timeserted, resealed, etc. back in June '08 at 54306 miles. It also had the coolant crossover done (seems common on '00+ Northstar). My only complaint is my slight "miss", which has been narrowed down to my camshafts. Personally I think it's a small vacuum leak because when I powerwash my engine it always misfires. It still runs like a bat outta hell though...
  7. #171
    Machster's Avatar
    Machster is offline Cadillac Owners Member
    Automobile(s): 2000 STS!
    Jun 2006
    9
    I have a 2000 STS with 362,000 km and still working fine. I love it. It was getting a little sluggish so I replaced the fuel filter and got back the 100 hp it was missing. Hey ryannel2003, you mentioned about having the HG's replaced, Timeserted, resealed, could you explain, thanks. I am looking at a '96 Eldorado, only driven in one winter, 129,000 km, spotless top and bottom. Asking $4,300. I am just worried about head gaskets, would anyone like to give me there thoughts on what percentage of these Northstars do blow gaskets. I heard the 2000 + have used larger head bolts so they don't pull in the aluminum blocks and release the gaskets. My brother has a '99 STS and had his blown.
  8. #172
    Apr 2007
    New Bern, NC
    26
    3,718
    The car had been having issues with Low Coolant messages, throwing a few codes, and had been generally running poorly. At this time I didn't own the car so the first owner traded it in on a newer '08 STS and when I had inquired about buying the car they said it had some motor trouble. I personally think the HG didn't need replacing because the car did not show any obvious signs of HG issues (using coolant, white smoke, etc.). The coolant crossover did have to be done so I figured the dealer went ahead and did the HG just to be on the safe side of things. They also did a reseal on the bottom end and a rear main seal (even though the car didn't leak any oil) again, because that is another common Northstar complaint.
    There really isn't a number out there that could rationalize how many Northstars have had issues. Some have problems from the beginning, some don't ever have a problem. I don't think the '96's were as prone to this failure as the '97-'99's were and I'm not sure why. It could be something to do with coolant, it could be the design.
  9. #173
    May 2009
    NY
    30
    54
    Well, I bought a 1997 Seville STS with about 84.5k miles on it, I've put almost a thousand miles on it in two weeks lol. What can I say it's fun to drive. No major issues yet, it had a "Service ride control" message but a GM dealer fixed that, it was just a disconnected sensor. Also said 'check coolant' but I added some dexcool and no problems since. The dealer checked the car over completely, and said it's in great shape. All I have paid for is to have the rear rotors machined (certainly not the car's fault) and for the labor of doing the checkup, oil change, and fixing that ride control sensor. Hope I can catch up to you guys and still be driving this car at 200k!
  10. #174
    Heart-of-Ohio is offline Cadillac Owners Member
    Automobile(s): 95 ETC. 66 Impala 427 Sport Coupe
    Apr 2009
    23
    '95 ETC with 102k miles and hope that it will pass 300K easily. The wife and I each want to drive it every day (she usually wins out) and I end up with the '04 Impala.
    I have thoughts of making the Caddy a show car but it's soooo much fun to drive.
  11. #175
    okcCADman is offline Cadillac Owners Member
    Automobile(s): 56,70,74,76 93 Allante, 96 Fleetwood, 02 ETC
    Dec 2006
    Oklahoma City, OK
    44
    Got a 2002 ETC here that just turned 283,000 miles. Runs great and fun to drive!
  12. #176
    Talamant3z's Avatar
    Talamant3z is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 Eldorado
    Jun 2008
    637
    Quote Originally Posted by okcCADman View Post
    HOLY SHIT! has the engine been rebulit or replaced the transmission? thats crazy for an 02 with damn near 300k good to know my 97 has 164 so i hope mine can last that long.
  13. #177
    CalicoCaddie is offline Cadillac Owners Member
    Automobile(s): 1995 Deville 1983 Seville
    Jun 2009
    40
    10
    164170 miles
    262598 kilometers
  14. #178
    AlBundy's Avatar
    Jul 2005
    Chicago
    4,992
  15. #179
    quaid99's Avatar
    quaid99 is offline Cadillac Owners Member
    Automobile(s): 1999 STS
    Dec 2008
    Ontario
    54
    5
    Hi
    My 1993 STS has 369,000 still runs great and HG has not been done that I know from previous owner.
    I will post picture tomorrow
    jounier11 and jounier11 like this.
  16. #180
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    Quote Originally Posted by jam224 View Post
    I have a 97 DeVille with 107400 original miles, which I know is not much compared to some of you. To figure out whether or not I can expect much more out of this engine, I would love to see how many of you have Northstars with higher mileage. If your engine is not the original, please let us know. Any major problems along the way would also be helpful, with mileages. I think that a thread like this could really help some of us anticipate problems and estimate the life of our engines!
    Thanks,
    Jim
    My entry:
    107400 miles original
    no known major problems
    now leaks a little oil (began around 100k)
    My '93 STS has some of the 'unlucky' engine problems like little oil leaks. I replaced the Northstar with a simular milage used one, even though I serviced much of the engine bay issues like the wiring harness, changed out as much of the gaskets /oil seals I could. The main problem ( besides the GM Manufacturer's DEFECT headgaskets that GM screwed everyone on, by IGNORING IT)
    It's replacement parts!! Injector - plastic fittings & vacuum parts are not around anymore. Fortunatly, I have the entire spare injector assy & throttle body.
    Unfortunatly, the fun is gone working on my car because I don't have the diagnostic tools.
    I am selling mine, for a very nice '93 Mercedes 500 SL, that won't have a headgasket problem.
  17. Remove Advertisements
