High Mileage Northstar Thread: Who can beat me? - Page 11
Page 11 of 30 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 151 to 165 of 449
Like Tree149Likes
Northstar Engines and System Technical Discussion Discussion, High Mileage Northstar Thread: Who can beat me? in Cadillac Engine Discussion; Originally Posted by MrPibb Hey everyone. This is my first post here. I am not a Cadillac owner(yet), but I ...
  1. #151
    John Luciano is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Seville STS
    Nov 2008
    San Gabriel Valley, CA
    6
    Re: High Mileage Northstar Thread: Who can beat me?
    Quote Originally Posted by MrPibb View Post
    Hey everyone. This is my first post here. I am not a Cadillac owner(yet), but I came here looking for some advice. I am in the market for a DTS. I have found one at a local Cadillac dealership for $4999. It is a 2003 with 182,000 and some change. The price is affordable and the pictures look ok from what I can tell(no torn up interior, exterior doesn't look like its obviously been hit and patched back together, etc). I am a bit nervous about buying one with that many miles on it. That's over 30,000 miles a year and I don't know how well the previous owner took care of it. Any questions, comments or advice would be appreciated. Thanks.
    If the vehicle is as nice as you describe, it would suggest to me that it was one of two things.
    1. A limo service vehicle - this is OK. Most limo companies service their cars on a maintenance schedule religiously & if it was highway miles, then it is probably a more solid feeling/running, first private owner or company car as opposed to multiple "city driving" owners.
    2. A privately owned car that was used for long distance commute. Possibly a salesman's car? In this case it was probably on a more rigorous maintenance schedule as well.
    Check with your local Cadillac dealer. They might be able to give you some insight into the service history if it was brought to a dealer for warranty work, routine maintenance, or otherwise.
  2. #152
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,628
    MrPibb, Northstar engines are tough engines. If mistreated they can be destroyed like any other engine, but as long as the oil maintenance was kept up, and hopefully the cooling system as well, I'd say go for it. Take it for a test run and make sure the temp guage stays on the 12 o'clock mark (creeping up slightly above is OK as long as it comes back down right away) and that it shifts smoothly. Check the oil for cleanliness and open the oil cap and take a peek in there as well at the heads. If it looks good and clean (aluminum color or slightly goldish/yellow) then the oil's been changed fairly regularly. If it's dark or black like tar, stay away from that Northstar. The first place oil builds up and turns to sludge in a N* is in the ports behind the chain tensioners. But I've seen N*'s with over 200,000 miles (359,000 kilometers to be exact) in great condition on the factory build- burning no more oil than what you'd expect for a N*, and no knocks or funny sounds. The lower timing chain tensioner is the first to wear out, but some last longer than others- depends on the amount of splash oiling. That's something we all take a chance on. The chains last damn near forever. The intermediate cam sprocket and mount can wear out too, but again that depends on oil and maintenance.
    Also, check for irregular noises and knocks as usual. cv joints and wheel bearings should be on the repair list for a car with that amount of miles- if they haven't been recently done. If you go to the right places, these parts won't hit the wallet too badly.
  3. #153
    karies is offline Cadillac Owners Member
    Automobile(s): 95 STS
    Nov 2008
    vancouver, b.c
    29
    17
    well my sts has 298xxxKM's at the moment and it now has HG and rod knock, transmission was replaced less then 3000KM ago.
  5. #154
    JacksonvilleDeville is offline Cadillac Owners Member
    Automobile(s): 1996 Deville
    Aug 2008
    Jacksonville Fl
    89
    1996 and 175,000 hard earned miles.
  6. #155
    [NortHStaR]'s Avatar
    [NortHStaR] is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac DeVille
    Aug 2008
    Phoenix, AZ
    25
    279
    My 1999 DeVille has 133,000 miles nothing major done exept the usual head gasket , but the motor looks great on the inside and im going to hope for over 300,000!
  7. #156
    sts777 is offline Cadillac Owners Member
    Automobile(s): "96 STS Black
    Sep 2006
    Loveland,CO
    15
    Well...I'm up to 324,000 miles and she's runnin' better now than when I got her at 70,000...1 radiator,1 fuel pump,1 alternator,1 a/c compressor,2 blower motors,new frt. pulleys/tensioners,1 new cat,1 cruise module,1 egr valve and brakes,tires,struts....still gets the looks...28mpg hwy and uses only 1 qt/3,000 miles! Let's see if we can trip the light fantastic by gettin' her to go to insane unheard of mileage!!! Yeah!!! '96 STS black w/dark wine interior.
  8. #157
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,951
    Wow sts777....that is awesome! And no head gasket failure. Sweet!
  9. #158
    nojuice is offline Cadillac Owners Member
    Automobile(s): 2001 deville
    Jan 2009
    53
    I sold my '99 Deville last November and it was running strong at 182,000 miles
  10. #159
    Phil Errett is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    7
    1999 STS - Just turned 340,069 kilometeres/204,041 miles.
    Last year bad years for break jobs - multiple rotors warped and replaced.
    Head gaskets about five years ago.
    Starting to get computer ignition problem - not yet solved.
  11. #160
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    544
    Had a 95 STS that was still running on original engine at about 285000, but we got rid of it and I don't know how it is doing now.
    Still have a 2000 DHS with 270000 miles, has broken a couple of engine mounts and front cylinder head was rubbing 1/2 way through the upper radiator hose. Orig engine and trans and neither has ever been opened up. Cracked the radiator last out of town trip and hopefully after rebuilding the cooling system (new thermostat, pump, belts, tensioners, crossover gaskets, radiator, surge tank, and hoses, all of which are original!) and new motor mounts will continue to serve me for another 100000 +.
  12. #161
    Talamant3z's Avatar
    Talamant3z is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 Eldorado
    Jun 2008
    637
    163xxx on my 97 eldo
  13. #162
    Mr 5.19. is offline Cadillac Owners Member
    Automobile(s): 03 Seville STS
    Apr 2009
    Cali
    30
    61
    I'm still on the low side only 67K... one day, one day.
  14. #163
    chev60 is offline Cadillac Owners Member
    Automobile(s): deville
    Apr 2009
    58
    1
    '96 DeVille--167,000 - replaced front wheel hubs, and of course, the a/c blower motor
  15. #164
    scmo3033 is offline Cadillac Owners Member
    May 2008
    maine
    my 1997 ETC has 145k on it now and runs perfect
  16. #165
    duramax1980 is offline Cadillac Owners Member
    Automobile(s): 2001 Seville STS
    Apr 2009
    3
    I ran a '97 SLS up to 220k before selling it to my brother. He hasn't had any engine trouble and is at 260k.
  17. Remove Advertisements
