2003 SLS ECM code: DTC "P0300
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 2003 SLS ECM code: DTC "P0300 in Cadillac Engine Discussion; "Engine Misfire" Anyone care to assist me with this? To date, I have replaced the crank sensors but not the ...
    scottio is offline Cadillac Owners Member
    Mar 2005
    Nashville, TN
    56
    6
    "Engine Misfire"
    Anyone care to assist me with this? To date, I have replaced the crank sensors but not the cam sensor, the alternator and cleaned both coil packs. It runs great but MIL flashes 15 or 20 times then sets to on. Any suggestions?
    Scott in Nashville
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    ExclamationRe: 2003 SLS ECM code: DTC "P0300
    One of the most common GM OBDII codes.
    Po300 is engine misfire detected. You can see which cylinder using a GM Tech 2. We have a GM Tech 2 and are in Nashville (near Brentwood.)
    The flashing check engine light is indicating that the miss is bad enough to potentially damage the cat converter.
    Could be bad plug or coil pack.
    Logan Diagnostic
    www.airbagcrash.com
    www.ledfix.com
