Cleaning fuel injectors
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Cleaning fuel injectors in Cadillac Engine Discussion; At what mileage should the fuel injectors be cleaned and what are some symptoms that they need cleaning? I have ...
    dom418 is offline Cadillac Owners Member
    Dec 2004
    48
    At what mileage should the fuel injectors be cleaned and what are some symptoms that they need cleaning? I have a 98 eldo with 50,000
    69
    82,383
    Re: Cleaning fuel injectors
    I have 98K and have never cleaned them. Last car ('92 Deville) had 125K and never cleaned them. Unless it starts missingand you are sure it is not ignition, I'd leave well enough alone.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    You shouldn't need to clean them. Most gas has enough detergent to keep them clean.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    I agree with Ranger and zonie77, the injectors do not require cleaning. If you're having driveability or starting issues, look at the wires or plugs. I've never heard of a "required" injector cleaning. The only time I've heard of anybody cleaning injectors was pure paranoia and that wasn't the problem after all. Look at the fuel pressure regulator, wires, and plugs before you go yanking injectors out of there.
    Mike
    Dec 2004
    48
    I have replaced the fuel pressure regulator, plugs, wires, even did a top engine clean but I continue to have a slight rough idle when the car is cold. Once it warms up, it runs great. It kinda sounds like I have a performance cam or something. The dealer was trying to recommend cleaning the injectors. Any other ideas on what it could be? It is not bad enough to set off the service engine light but it is more of an annoyance than anything. I was thinking a coil but would the problem get better once the car is warm.
    Sep 2003
    Arizona
    3,531
    It is possible to need a cleaning. You could run a can of inj cleaner and see what happens. You have to be careful though. Too high a concentration will hurt the fuel pump. It attacks the insulation on the windings.
    Follow the instructions, add it at the gas station and then fill the tank.
    gman is offline Cadillac Owners Member
    Dec 2004
    41
    Check your intake manifold bolts! I had the same problem with my 98 eldo(check postings in seville/eldo forum). My theory is that the bolts may be loose and that will cause a small vacuum leak. As the vehicle warms up, the small gap between the manifold and the engine decreases. It is a simple process and it will save you time and money if you check bolt tightness. If they are loose, tighten them to 10Nm.
    Feb 2004
    FL
    2,250
    My engine with 67k needed injector service... at least 2 injectors were stuck open enough to stream fuel.
  11. Remove Advertisements
