Long Crankin
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Long Crankin in Cadillac Engine Discussion; Hey, My 96 Eldo sometimes requires about a 10 sec crank over to start. This seems excessive compared to my ...
    Benlomand's Avatar
    Benlomand is offline Cadillac Owners Member
    Automobile(s): 96 ETC, 93 Deville
    Mar 2005
    St.Pete, Fla
    28
    Long Crankin
    Hey,
    My 96 Eldo sometimes requires about a 10 sec crank over to start. This seems excessive compared to my other vehicles. I don't put my foot on the gas at all and at times I smell gas too. Runs great once running and the mileage on my last trip averaged 22+mpg. What's up?
    Benlomand's Avatar
    Mar 2005
    St.Pete, Fla
    28
    Re: Long Crankin
    Could I be losing fuel pressure at the injectors? Did I see something on the forum about fuel rail recalls?
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Long Crankin
    Fuel pressure regulator may be leaking.
    turboost is offline Cadillac Owners Member
    Mar 2005
    10
    Re: Long Crankin
    I just bought a 96 sts and before we left town it had a 5 second crank which I thought was weird. So I turned it off and tryed it again and it started right up but I did smell some gas but nothing on the ground. Does this sound like a FP regulator problem?
    Sep 2003
    Arizona
    3,531
    Re: Long Crankin
    yes
    Benlomand's Avatar
    Mar 2005
    St.Pete, Fla
    28
    Re: Long Crankin
    Saw another long post on this same problem. I'm calling the dealer first to see if I've had the recall on the fuel rail and go from there. My problem occurs only when the engine is warm.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: Long Crankin
    I'm betting on the fuel pressure regulator. When the recall is done to replace the fuel rail, they re-use the original FPR, so having the recall done won't fix anything. If it's losing pressure due to cracking of the fuel rail, you will smell gas. You still need to get the fuel rail recall done even if you replace the FPR before that, or you could have them put a new FPR on it while they're doing the recall. Not sure what that would cost.
    Mike
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Long Crankin
    Quote Originally Posted by Benlomand
    Simply open the hood and look at the fuel rail. If it is plastic then the recall has not been done. It is is stainless steel tubing then it has had the recall completed.
    The FPR is equally easy to check. With the engine idling, pull the vacuum hose off the FPR. Watch the vacuum nipple for several minutes for any sign of fuel seeping out. There should be none.
    97BlueDeville's Avatar
    97BlueDeville is offline Cadillac Owners Member
    Automobile(s): 06' DTS
    Sep 2004
    Aurora, CO
    41
    65
    Re: Long Crankin
    Bob.. You're very smart!!
  12. Remove Advertisements
