00 DTS - Starting issue
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, 00 DTS - Starting issue in Cadillac Engine Discussion; I don't know if this is "just me" or what.. But since I've had this car (about a week), I've ...
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    I don't know if this is "just me" or what.. But since I've had this car (about a week), I've turned the key and had the car either stall or not start all the way, three times. It's as if I'm not holding the key in the 'start' position long enough. If I'm not mistaken, this happened to me a few times with my 95 Eldorado Touring Coupe as well, when I first got it - BUT - I could be wrong.. Does this happen to anyone else - or did it happen when you first got your Northstar Cadillac (not saying that this is a Northstar issue, just a 'newer' car issue). Maybe I'm just used to older cars since my last two have been an 87 Vette and a 95 Fleetwood (non-Northstar)...
    If this site has helped you save money, please consider helping it continue to do so. Click here for information!
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: 00 DTS - Starting issue
    ive heard if the cam sensors are screwing up that the cranking time takes longer ....may want to look into getting those swapped out ....Bbob should swing by to let you know come monday (hes on vacation i think)
    May 2003
    14,607
    This belongs in the northstar section .....LOL
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    So it IS a Northstar issue! Okay. Moving now...
    May 2003
    14,607
    just busting your chops there sal ...these oppertunitys only come around once and awhile
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Oh, that's okay. I need a good "speaking to" every now and then.
    May 2003
    14,607
    btw sal , here is where i heard about y2k cam sensors and starting :
    http://www.cadillacforums.com/forums...nsors+starting
    read what bbob says about it
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    That thread is on crank sensors, not cam sensors.
    lowscola's Avatar
    lowscola is offline Cadillac Owners Fanatic
    Automobile(s): DeVille DHS
    Sep 2003
    229
    Quote Originally Posted by El Dobro
    I have had to replace both crank & cam sensors...
    http://www.cadillacforums.com/forums...ad.php?t=15870
    http://www.cadillacforums.com/forums...ead.php?t=7955
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    On the 2000 year cars, bbob has recommended that the crank position sensors be changed out with new ones, which have been redesigned. Sal, have you looked for codes? I would just do the crank position sensors because they're a known problem. After that, I would start looking at the FPR.
    Mike
    May 2003
    14,607
    sorry didnt know the northstar was quadruple redundant when it came to knowing where the no 1 piston was ....figured i could say "cam sensor" and id be ok ....apprently it has 2 of each .....werid ....youd think if the cams were not variable that the computer could figure out where the cams were relative to the crank ...but then again why doe sit care where the cams are ? should it just be concerend with one of them to determine spark timing ?
    NOTE THIS DOESNT APPLY TO Varible Valve Timing!! i know why in that case
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Replace the crank sensors.
  15. Remove Advertisements
