Timesert or not?
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Timesert or not? in Cadillac Engine Discussion; Hi all, thank's for a great forum! I'm a lucky owner of a sts-93 with N*, maybe not so lucky ...
    CooL is offline Cadillac Owners Member
    Automobile(s): Seville STS
    Apr 2004
    11
    Timesert or not?
    I'm a lucky owner of a sts-93 with N*, maybe not so lucky now The engine have run great all the time but now it losing coolant! I did a compression test and find out that cylinder number 2 had low compression, about 3bar. All other cylinders had between 9,5-10bar. It is probably a blown head gasket so I must replace it! I have read many topics about Timesert but it is very hard(impossible) to find them here in Sweden. The question is, is it always necessary to use Timesert even if all the threads are in good contition?
    Bad english, hope you understand
    Thx
    haymaker is offline Cadillac Owners Fanatic
    Sep 2004
    266
    Re: Timesert or not?
    I think most of the people here that have removed their older N* cylinder heads have found damaged block threads and didn’t have a choice as to installing the time-serts. I know when I removed the heads on my 1997 N* several of the head bolts carried the block threads out during there removal. You need the time-sert kit to repair any of the head bolts female block threads that are damaged even if it is only one bolt hole, so you do one, you might as well do them all while you are in there. IMHO even if you were lucky enough to remove the head bolts and the block threads remained intact they could yet fail during reassembly. If I were you I would just plan on time-serting all twenty head bolt holes if in fact the head gasket is proven to be the problem. The cylinder leak down test would appear to be the preferred test for a leaking head gasket. Did you email time-sert http://www.timesert.com/ and inquire as to the purchase and shipping of their repair kit?
    Good luck..
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    There was someone when I first got on the forum that had a thread fail during the final torue sequence. On the ones I did we had many holes with pulled threads, not just one per block.
    I'd look into getting the timesert kit shipped to you.
    Loose screw is offline Cadillac Owners Fanatic
    Automobile(s): 94 concourse, 99 sts
    Feb 2004
    60
    150
    The older the engine and/or the higher the miles, the more and more like that if you don't have to do a Time-sert to day you will very soon and tearing down an engine and putting back together really stress the threads. They don't get stronger with age and use that is for sure. With your engine being a 93 I would certainly do the Time-serts. I am doing a 94 now and all the head thread were good and looked good but I did them anyway because of all I had read and I am glade I did and they worked well but when tightening the mains down today one of those failed and they seldom do, so I think that is an strong indicator that the head threads could have gone at any time and probably would have in a few hundred or thousand miles after having gone throught the additnal stress of being reused. Don't trust them - Time-sert them, and do all the head threads.
    Make sure to order enough serts the kit dosen't come with enough to do both heads.
    Sep 2003
    Arizona
    3,531
    I forgot to mention that about the kit. The kit is for 1 head. You must order another 10 inserts to do both heads.
    Apr 2004
    11
    Quote Originally Posted by zonie77
    OK, I now know what I have to order, a Timesert-kit + 10 extra inserts. Maybe we have another solution on this sida of the Atlantic, it is Kobsert. http://www.boellhoff.com/web/germany.../ko_start.html
    Someone who can post a link to a cheap GM online-shop and a seller for Timsertkit?
    Tanks, again!
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,208
    Kobsert=too short. Not enough threads.
    Sep 2003
    Arizona
    3,531
    www.timesert.com
    You should get the info on the timesert and see if Kobert has a comparable insert. It would have to be the same or longer. Good luck. Let us know what you find.
  11. Remove Advertisements
