Heli-Coil removal?
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By 97EldoCoupe
Northstar Engines and System Technical Discussion Discussion, Heli-Coil removal? in Cadillac Engine Discussion; Hey guys, I am hoping you can provide some insight in my current situation. I am in getting ready to ...
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    264
    Heli-Coil removal?
    Hey guys, I am hoping you can provide some insight in my current situation. I am in getting ready to stud a N* with CCC studs, but the car was previously worked on and had helicoils installed before! So I have a couple of questions. I am told that a screwdriver filed down at about a 10 degree angle can get the coils out. Does anyone have a picture of this by chance? Or a different method to get them out? I know there is a helicoil removal tool, will that work? Lastly, I am assuming I cannot just drill them out, without damaging the block and digging helicoil pieces into the engine.
    Any other insight is greatly appreciated.
    Thanks!
    68
    82,063
    Re: Heli-Coil removal?
    Never had to remove one, but this should help.
    http://www.google.com/search?q=helic...ient=firefox-a
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    Hi Ranger,
    Thanks for the reply. I did do some google-foo before posting here too. I could not seem to find anyone to is going as deep as I am. A lot of the forum posts I found were basic removals. Not too deep. I will be ordering my studs from Carroll tomorrow. I have spoke with him previously and he mentioned the screwdriver tool also. If I am lucky, maybe he can loan it to me or send me some pictures.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,202
    Studs or not, I don't like the sound of this Heli-coil thing. That block has already been drilled and tapped oversize to accept the coils. I hope this works out OK ..............
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    Quote Originally Posted by Submariner409 View Post
    Hi Submariner,
    Thank you for the reply. I agree, helicoils are bad business. The good thing is they were installed to accommodate oem bolts. So the holes are not actually any bigger. When I was originally planning this, I spoke with Jake and Carroll about it and they said their studs will work fine with a helicoil block. That being said, if there is interest, I can post the size comparison with the coils, oem studs, and Carrolls once I get those darn things out.
    My one hope is they did not use loc-tite on the helicoils. I believe you are not supposed to, but instructions usually can't fix stupid. The car never overheated before I put it away, so no concern on the block, but I do not want to take a torch to the bolt holes if I can avoid it.
    Feb 2006
    56,202
    There were some pictures - maybe here in Northstar Performance - a couple of years back - someone was removing Heli-coils from a Northstar block by twisting one end out - sort of like collapsing a spring by twisting it smaller in diameter. I have removed several from iron blocks - no fun; no fun at all.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    You bought the studs from Tim, ive seen him remove helicoils from a Deville before, hit him up
    Carrollcadillac@live.com
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,621
    Drill until you hit the heli-coil. That steel wire is very hard, you can't drill it. Tap the drill up and down on the top of the coil while the drill is turning, apply a bit of pressure. It will catch the coil, unwind it to the point where a part of it is protruding above the deck surface. Take the drill out of the hole, grab the wire with a pair of pliers and pull it out. It will unwind and come out. Works every time.
    arctic_man and 04GrandAmGT like this.
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    Quote Originally Posted by 97EldoCoupe View Post
    Hi Jake,
    Thank you for the reply. This is exactly what I was looking for. Hopefully, I can get drilling this week and post some results. My friend and I started this back in late May. So far it has been pretty fun, but we took off the heads and saw how far down the helicoils were and just shared a few curse words.
  12. Remove Advertisements
