Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Wanted to clean EGR but what have those engineers done now
    jsjag is offline Cadillac Owners Member
    Automobile(s): 1995 Deville Concours
    Aug 2005
    89
    Went to pull the EGR valve on my 95 Deville Coucours, should be simple right? Two bolts holding it on and away we go but nope. Some engineer decided to mount the fuel rail on top of the oine EGR mounting bolts. What!!!!!!
    Really? Seriously? Will this simple 15 minute job turn into hours or am I missing something?
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    Re: Wanted to clean EGR but what have those engineers done now
    It probably looks totally different with the engine on a stand.
    We always swore the engineers should be the first ones to work on there creations.
    Aug 2005
    89
    Lightbulb Re: Wanted to clean EGR but what have those engineers done now
    Been reading about this matter. There may have been a recall or retrofit to the stainless fuel rail. I'm guessing that it was out of the realm of engineering to create a two part fuel rail attachment at the EGR that would allow removal from the EGR bolt.
    Engineering disasters cost we the consumer a lot of money and I consider this EGR arrangement to be a disaster.
    Quote Originally Posted by amunderdog View Post
  5. #4
    69
    82,273
    Nope, you're not missing anything. I can't recall for sure, but I though it was a bit easier after the recall was accomplished and the SS fuel rail was installed. You have had that done, right?
  6. #5
    Aug 2005
    89
    We got the car in 07 and it had already had an engine replacement. If it is SS it is poor quality because I can see rust on the outside but maybe it is poor quality. Other than the engine transplant that the previous owner had done, I've only done tuneup stuff.
    If there was a recall could it still be in effect? Is there a dangerous defect hazard that I don't know about. Sometimes things for as long as the life of the car. My attack seat belts in the Jaguar are warrantied for life.
    If the recall still used the same method to attach the rail, I doubt if it is easier. If there is a lifetime recall I could call the local caddie dealer and maybe they can run the vin. It is a Calif. car and I am in the northeast.
  7. #6
    69
    82,273
    Recalls are safety related and I do not believe there is an expiration date. If your recall was done you will have a SS fuel rail. If not, it will be a black nylon rail (yellow arrow) running from injector to injector like the picture.
    This diagram shows the individual nylon "rail" between injectors.
    This is what the SS rail will look like.
  8. #7
    Sep 2007
    Wilmington, NC
    13,969
    call any cadillac dealer and have them run your VIN through the warranty/recall system and it will show up if it is still out there
  9. #8
    Aug 2005
    89
    The car is at work with my wife but I am fairly certain that I have the second picture with the SS rail.
    But if I remember the supply lines look like those in the first picture and I definitely have the connector piece that fits over the EGR bolt.
    I don't have a quick connect tool to loosen the fuel rail/supply lines but I can get one.   I'm just PO'd at the moment that I have to go through the extra work to remove the rail that IMHO is crazy. I have 6 cars in my house and I am always busy on them. Well make that 5 cars because two weeks ago the XJ40 engine seized and I have no idea why.
    This I do know, I've had the EGR off every one of our cars (to clean them) except the Caddie and without an exception I had them removed in 15 minutes or less.
  10. #9
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,847
    The straight runs on the steel fuel rail are covered in a black plastic shield that incorporates the injector locks. Don't let the black plastic sway your view- the rails LOOK very different.
    If the XJ-40 engine is anything like the old XJ-140 MC engine, the crank split in half at the center main bearing.
  11. #10
    Aug 2005
    89
    I put a socket on the crank pulley nut and had a big breaker bar, that sucker would not budge! Had the car 13.5 years and got my money's worth but now I am jag-less. The first time in almost 19 years that I am jag-less.
    I know that I saw rust (#00 steel wool would probably take off) on the outside of the rail and it has to be metal. IMHO it isn't the best grade of SS. I have a SS counter out of a commercial kitchen and I use it outside. It has been sitting outside for 30 years and there is only rust at one or two the weld spots.
    I'll double check tonight when my wife gets home and post a picture.
    Quote Originally Posted by Submariner409 View Post
  12. #11
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Ive always like Jaguars
  13. #12
    69
    82,273
    Not if it was a recall replacement. As I recall those where plain old shiny SS.
  14. #13
    Aug 2005
    89
    Here is what my fuel rail looks like.
  15. #14
    Feb 2006
    56,847
    Yup ^^^ - Whole different critter from the 2000 and later rails. Live and learn.
  16. #15
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    I remember it was quite easy to shift that out of the stud.
  • You may not post replies
