Wanted to clean EGR but what have those engineers done now - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Like Tree3Likes
Northstar Engines and System Technical Discussion Discussion, Wanted to clean EGR but what have those engineers done now in Cadillac Engine Discussion; Jsjag, I tried to respond to post #13 but inadvertently edited it instead. Sorry. Anyway, the recall was performed on ...
  1. #16
    68
    81,761
    Re: Wanted to clean EGR but what have those engineers done now
    Anyway, the recall was performed on that car as you do in fact have the SS rail.
    Quote Originally Posted by Submariner409 View Post
    Yup ^^^ - Whole different critter from the 2000 and later rails. Live and learn.
    Only reason I new that Sub was because I had a '97 and had been through the recall.
  2. #17
    jsjag is offline Cadillac Owners Member
    Automobile(s): 1995 Deville Concours
    Aug 2005
    89
    Last night I fogged the intake with SeaFoam, let it sit overnight.
    My wife drove the car to work this morning and said that it smoked for about 1.5 miles but no illuminated CEL. Maybe it cleaned things enough that the EGR stem is working. I am sure it didn't clean the EGR as well as I do when I clen them.
  3. #18
    68
    81,761
    Seafoam is snake oil and won't do a thing for the EGR valve. Is it is sticking, the only way to clean it it so remove it and scrape the pintle valve and shaft.
    maeng9981 likes this.
  5. #19
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    I need to come up with a fix in a can/bottle, i'll name it magic fix, yea that's it. And i'll ensure its at the checkout stand of every autoparts store . Then i'll be able to retire by 40.
  6. #20
    Aug 2005
    89
    Maybe true --- the snake oil thing but something happened overnight. If the car thinks it is happier today, I jsut won't tell the Ack Ack. We call her Ack Ack --- Billy Joel song where he sings "bought a Cadillac Ack Ack Ack."
    The guy that works PT at the parts store used to run the Olds/Caddie service dept, he is now at VW. Anyhow he said that they used to run GM Tec through and it did help but the GM Tec was used only in the worst instances. He is the one that suggested SeaFoam.
  7. #21
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Thread is only 3 days old which is not long. I assume you have not attempted to unbolt fuel rail and lift it to extract egr? You could spend $100 on new egr but that's your call.
  8. #22
    Caddydrummer67's Avatar
    Caddydrummer67 is offline Cadillac Owners Fanatic
    Automobile(s): '02 ETC 32,000 miles 2002 F55 STS 78,000 miles
    Jun 2012
    Black Hills of SD
    239
    Yeah, yours doesn't look exactly like mine on my '97 ETC, but I did mine, and it was quite easy. Just remove the screws holding the fuel rail down and then gently pop the rail and injectors out one by one starting close to the EGR and moving away as you go. Be careful, don't pull too hard, they should pop out fairly easily. Then you can pull the fuel rail up just enough to get to the EGR screw/nut. Also, I would stuff a rag or something down underneath the EGR to catch the nut in case you drop it down into engine bay oblivion. I learned this the hard way. Oh well, an extra trip to the hardware is the price you pay sometimes. The injectors should pop right back down when your done. There is actually a kind of "pop" sound when you get them re-seated correctly.
    Might as well check the FPR while your at it. Pull the line from the side of it, if it drips fuel, you need a new one. If you change it out, make sure you release the fuel line pressure at the valve on the end of the rail first.
  9. #23
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    in a one gallon jug put dex-cool into it then put those ACDelco Sealant tabs inthere shake it up and name it Dex-Fix.
    CadillacLuke24 and vincentm like this.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
  10. Remove Advertisements
