Oil Burning Eldo, 1997 Etc..
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Oil Burning Eldo, 1997 Etc.. in Cadillac Engine Discussion; I have a 1997 eldo, so far my oil pump,water pump, fuel rail, all pumps struts, motor mounts...........have all blown ...
    bostonscreenman is offline Cadillac Owners Member
    Dec 2003
    4
    I have a 1997 eldo, so far my oil pump,water pump, fuel rail, all pumps struts, motor mounts...........have all blown up..
    The oil burning is all I really care about...this Northstar motor really is not that
    great ...unless I got the one lemon out there..oh yah head gaskets, bearings soon...aaaaaaaaaaaaaaaaaaaa!!!! what a financial burden...
    HELP
    david1549 is offline Cadillac Owners Member
    Sep 2004
    East Wenatchee, Washington
    71
    32
    Re: Oil Burning Eldo, 1997 Etc..
    I just posted this under toolmans "Oil Level" post;
    Quote:Originally Posted by bostonscreenmanI have a 1997 eldo ETC, it actually burns oil like a siv...my only problem has been the oxygen sensor....82000k miles
    if anyone elso has a burning problem let me know...
    I had the same problem. I've got a '96 SLS with 94,000 miles on it. I allowed my mechanic to change my oil, I had no problem with his work and left it up to him as to what brand of oil to use. It was an Exxon station and I'm sure it was the oil he made the most profit on. It used 3 quarts in 1200 miles.
    I've always been a Pennzoil guy so I went to one of those quickie oil change places and had them put in 10/30 Pennzoil. I'm at 2500 miles after the change and it hasn't used a drop.
    I also have an O2 sensor failing, it generates a slow response code. I just had that same one changed six months ago. Someone smarter than I would have to determine the cause and effect of high oil consumption and O2 sensor failure.
    Dec 2003
    4
    Pennzoil Here I Come..my Sensor Is Out As Well, The Engine Light Has Been On For A Year As Well, The Codes, When Checked Were Going Nuts, Over 30 Different Ones...but My Caddy Mechanic Say All Is Well?? Aaaaaaaaaaaa
    Yah Until The Next Major Repair Job......thank You Dave For Feeling My Pain
    dwight.j.carter's Avatar
    dwight.j.carter is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Seville STS
    Aug 2004
    Des Moines, Iowa, United State
    37
    2,067
    You guys ought to read up on the oil consumption on the Northstar. I read in another post that it is because of the agressive cam design and it takes more oil into the upper engine to protect those parts and mine burns oil also but I would rather it burn oil than the motor blow at 100000 for lack of oil.
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    Quote Originally Posted by dwight.j.carter
    The higher than most engines oil usage, is primarily caused by a very aggressive cylinder hone pattern. Its purpose is to keep the cylinder walls well lubricated for high RPM running. Occasional WOT and using 3rd gear to decelerate will keep the rings free and keep oil usage to a minimum.
    A normal oil consumption should be about 1 quart in 1200+ miles. I tend to use about 1 quart in 1500+ miles.
    The stock Northstar cams are actually fairly mild. A quick way to more power is to replace the camshafts; problem is I don't think they would pass the strict emissions test.
    Cadillac Hot Rod Fabricators has some interesting parts and engine modifications for the Northstar.
    -George
    Aug 2004
    37
    2,067
    Yeah I saw this site even before I started posting on here and I would love to take my STS down to them and rebuild the engine with an extra two hundred horse and have a 500 horsepower car. My god only in my dreams.
    Sep 2004
    71
    32
    You guys that accept oil usage in a $40 or $50,000 automobile as a matter of course, well, It's, Its................Drive a Ford
    68
    81,889
    Quote Originally Posted by david1549
    NO THANK YOU. How many fords do you know of that have 325K on them?
    http://caddyinfo.ipbhost.com/index.php?showtopic=5408w
    You seem to consider oil usage a bad thing. I used to til I understood it. I've said it before and I'll say it again. Click on Technical Archive in the upper left coner and read up on oil consumption. Then you'll understand why this guy has 325K on the engine.
    91TexasSeville's Avatar
    91TexasSeville is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX-V8, 1991 Eldorado
    Oct 2004
    Near Houston
    66
    1,543
    Quote Originally Posted by Ranger
    I know of at least one, mine!
  12. Remove Advertisements
