99 N* rebuilt and burning lots of oil
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree3Likes
Northstar Engines and System Technical Discussion Discussion, 99 N* rebuilt and burning lots of oil in Cadillac Engine Discussion; I have went through with the time and money on my NS.The reason i rebuilt it is because of the ...
    NSDeville is offline Cadillac Owners Member
    Automobile(s): 99 deville
    Jul 2013
    fort wayne indiana
    25
    I have went through with the time and money on my NS.The reason i rebuilt it is because of the head gaskets. i did the timesert kit. i started it today and it runs perfect but burns over 1/2 quart of oil in five mins. All 8 pistons are soaked and when i pull the plugs, fresh oil is on them. The amount of smoke out the tail pipes is so bad i cant even describe. everything is new.. rod bearings piston rings.. honed walls.. valve stem seals.. pvc valve.. and more.. im lost... my grand father left me this beautiful deville in show room condition when he died. he told me to never let go of it and fix it in memory of him... i will not stop at anything...
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Re: 99 n* rebuilt and burning lotsss of oil
    Who installed the piston rings?
    Were the rings spaced according the manufactures specifications or the factory service manual?
    Usually, the northstar doesn't need a re-hone job because the factory cross-hatch marks are still visible after many thousands of miles.
    The northstar always seems to use a bit of oil, but you've got something abnormal going on.
    Were the valve stem seals the right ones and installed correctly?
    Did you modify or not replace something in the valve covers that fell out? Possibly a baffle?
    Since you had the motor rebuilt, you're going to have to mentally scruntize everything that was done.....
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    375
    What brand name are the piston rings?
    amunderdog is online now Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    I see this as your first post
    Hi
    You had it rebuilt or you rebuilt it?
    My 2 cents
    If you had it rebuilt - contact the rebuilder
    If you rebuilt it - Find a shop that speaks NorthStar and pay them to correct the motor about 3k.
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    49
    499
    What rings were used and were they installed correctly. I have totally rebuilt 2 Northstars and used gm rings and oil usage is minimal
    69
    82,269
    You honed the cylinder walls? That may be your problem. That is NOT recommended. Might consider a compression test.
    69
    82,269
    Quote Originally Posted by 98eldo32v View Post
    Here's one at 131K and anther at 170K.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Re: 99 N* rebuilt and burning lots of oil
    If the #2 piston ring (second compression ring) is installed upside down it acts like an oil pump - those rings have a tapered face and MUST be installed with the dot side up - their proper name is "oil scraper ring".
    That's probably most of your oil problem right there.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    What did you do with the top end? What rings did you go with, what hone/coarseness of grit (eg. 240 grit), what pattern? Did you check the end gaps of the rings and adjust prior to install? This is all vital information in determining the cause of consumption. Was there any rusting/pitting/scoring in the cylinders? Any wear or out of roundness?
    Make very sure oil level is correct (goes without saying) and not overfull.
    We will try to help.
    69
    82,269
    Don't want to hijack this thread, but haven't seen you in a while Jake. Hope all is going well.
    Jul 2013
    fort wayne indiana
    25
    ok i rebuilt the engine myself. i had my local machine shop clean my heads and block and deck everything to spec. i bought my rings from ebay using brand sealed power. i spaced the ring gaps accordingly. my gasket kit i bought had the wrong timing cover gasket in it... was for the wrong year. i knew something was wrong because the kit was labeled northstar 99-04? wasnt there differences? anyway im really leaning towards valve stem seals. i ran the car again today and had it running at 3000 rpm to see if it would clear or whatever. i only did this for less than 5 mins.. i shut it down and had a oil spill from my tail pipes about 3x5 foot big and i was down 2 quarts in my crank case... something is VERY wrong. i will do a compression test tomorrow and post. thanks everyone for the feed back.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    They did ur heads? Were cams installed when they went to shop? If they tore down heads, did they put valve stem seals back? Maybe they forgot? Sounds like u need to pull pistons and recheck rings? Than mic cyl diameter? Or check cyl wall surface texture.
    Feb 2006
    56,827
    I told you there is a chance the second compression rings are installed upside down. Can you absolutely verify they were installed dot up ???
    That is the ONLY way to pump that much oil out of the engine in such a hurry - valve stem seals would contribute, yes - but not that volume.
  16. #14
    69
    82,269
    Quote Originally Posted by NSDeville View Post
    Holy Exxon Valdez Batman! I'll say something is very wrong. That's not burning oil, that's hemorrhaging.
    97EldoCoupe and MoistCabbage like this.
  17. #15
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by Ranger
    LOL!!!
  18. Remove Advertisements
