95 SLS how to check coolant levels?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 95 SLS how to check coolant levels? in Cadillac Engine Discussion; I cant seem to find where to check the coolant level. I have the message check coolant level. So I ...
    halcyon026 is offline Cadillac Owners Member
    Aug 2003
    13
    I cant seem to find where to check the coolant level. I have the message check coolant level. So I look and find what i think is the lid to the coolant and it says check bottle for coolant level... I cant seem to find this bottle it speaks of. The thing i think is the lid is on the far passenger side of the car.
    Anyone know where to check the level?
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: 95 SLS how to check coolant levels?
    Look into the big res tank, pass side..... Look in the manual to see what the approx. level is supposed to be.....
    Aug 2003
    13
    OH! so im suppose to look inside it? Im use to a clear thing you can just look at. and the lid says "bottle" so i didnt think it was the black thing where it looks like the AC freon can sits.
    cadfan is offline Cadillac Owners Member
    Sep 2003
    47
    The coolant resev. that you are looking for is on the pass side of the engine. It is a black container that you will not be able to see thru. You will noticed a small coolant hose running from near the cap to a pipe under the intake/plen. cover. Fill it just to wear you see coolant in the bottle. Over fill it, you will just lose the extra. You may need to tap on the resev. to loosen any air bubbles that will get trapped on the level sensor. It could take time.
  7. Remove Advertisements
