Northstar into Chevy Beretta swap
Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By IXSLR8
Northstar Engines and System Technical Discussion Discussion, Northstar into Chevy Beretta swap in Cadillac Engine Discussion; Ok I've seen another thread on this but have not seen any updates from the guy. My question is, is ...
    90BerettaGTZ is offline Cadillac Owners Member
    Automobile(s): None soon to be Northstar beretta
    Jul 2013
    26
    1
    Ok I've seen another thread on this but have not seen any updates from the guy. My question is, is what is the easiest a implicated Northstar to get for an easy swap as far as modifying the harness to make it work and or computer to get it to function well in my beretta? I have 2 Gtzs but don't wanna cut them up so a buddy is giving me his wreck 90 gt with what already has a 3.1L 5 speed in I'd like to do a Northstar swap since I have to hack the front end anyway. I'm pretty good at fabricated as I'm a bodyman, so mounting and fitting the motor is no problem, it's the engine management I'm worried about any help would be appreciated thanks Ryan.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    PCM would have to go with it. You're a glutton for punishment, good luck
    IXSLR8 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    69
    Re: Northstar into Chevy Beretta swap
    Engine management is not hard anymore. There's a lot of Northstars in other cars, especially within the Pontiac Fiero community. I have two N*'s in two fieros. One using the manual transmission and the other using the Cadillac automatic tranny.
    With the Auto tranny Fiero, I'm using the stock 1996 Cadillac computer with some features deleted, such as the rev limiter, passkey security, ABS, EGR and some other stuff. It runs fine so far with no real code issues. My manual car has aftermarket cams in the N* and uses an LS1 computer and a Shelby Series 1 tune by AJ here on the forum. It has a random stall issues that still need to be worked out.
    There are other car platforms using the Northstar in their engine bay using engine management such as the Holley Commander (and newer self-tune version), mega squirt, and Haltech units.
    Stick with the 1995-1999 engines and its fairly strait forward. Wester's up in Alberta and AJ (PCM Calibrators) here on the forum can modify your Cadillac computer for your application.
    Would be a a lot of fun in a Beretta!
    drewsdeville and JoeTahoe like this.
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Good luck, Personally i havent done any huge swaps, but anything and everything is possible with enough blood and sweat haha, if you have any mechanical questions, we here at Northstar Performance will be more than happy to answer any questions you might have to the best of our ability, Have a wonderful Day.
  7. Remove Advertisements
