My First problem with my 2001 DTS if anyone can help?
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, My First problem with my 2001 DTS if anyone can help? in Cadillac Engine Discussion; While parked waiting for the missus, my 2001 dts stalled. After several attempts it eventually started up with the engine ...
    2001DTS_Ontario is offline Cadillac Owners Member
    Jan 2005
    18
    While parked waiting for the missus, my 2001 dts stalled. After several attempts it eventually started up with the engine light staying on. It ran fine all the way back home. After shutting it off, it does start but only after it turns over several times.
    I checked the codes by pressing the on/off and up button then left it cycle through the codes. The following is what was displayed..what it means ????
    IRC U1064 History
    U1016 History
    U1144 History
    PCM P0335 Current. - I looked on a chart and found it to be "CKP Sensor A circuit performance" ?????
    RCC u1000 history.
    Is the car safe to drive with these codes?
    Am I looking at $$$$ to correct? I do have an extended warranty BUT if the fix is reasonable I would pay myself.
    Any help or information is appreciated.
    EdM
    68
    81,917
    Re: My First problem with my 2001 DTS if anyone can help?
    Crank shaft position sensor. I seem to recall that was a problem on 01's or there abouts and it was redesigned. There are two of them. No idea on $$$. It is safe to drive but not reliable.
    Jan 2005
    18
    Thanks for the reply, I was more concerned about doing more damage rather than the cost of the repair.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    It's safe to drive, but it could still stall some more. There was a problem with the crank sensors in 2000 and 2001. I don't think the sensors are that much, but if your extended warranty covers it, use that!
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Replace the crank sensors with the latest versions availalbe from service parts. They have been superceded several times....
    Jan 2005
    18
    Thanks again, just been doing my homework on these things. I think I'm understanding what it does and whats involved. The extended warranty I have has a 50% refund clause if its not used. So I am being careful. If its anywhere close to the deductable I'll just pay cash. Thanks again all for the great response and advice. If I can ask another question..the codes that say History beside them, are they related to the above as well?
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    History codes are codes that there was a problem, but it doesn't exist at that exact moment.
    If the problem is happening currently, the code will say Current.
    Jan 2005
    18
    thanks again
  11. Remove Advertisements
