gas in oil
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, gas in oil in Cadillac Engine Discussion; i have a 95 sts and i pulled out the oil stick and i could smell gas on the stick ...
    black45 is offline Cadillac Owners Member
    Sep 2004
    10
    gas in oil
    i have a 95 sts and i pulled out the oil stick and i could smell gas on the stick what could it be
    Feb 2004
    FL
    2,250
    Re: gas in oil
    stuck open injector, or leaking fuel pressure regulator... that's about it. Unless you make really short trips, and the engine never gets warm......
    68
    81,917
    Re: gas in oil
    Most likely a leaky injector. A leaky FPR would leak into the manifold and be burned upon starting. A leaky injector will leak into the cylinder and seep passed the rings into the oil overnight.
    Sep 2004
    10
    Re: gas in oil
    motor wont turn over could it be locked up
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,215
    Re: gas in oil
    You've hydraulic locked the engine with raw fuel. Take out the sparkplugs and motor the engine with the starter. The cylinder that shoots gas out the sparkplug hole has the bad injector. Have a fire extinguisher handy.
    68
    81,917
    Re: gas in oil
    Quote Originally Posted by black45
    Ooh! You didn't say that at first. Yeah sure sounds like it's hydrolocked. Follow Dkozloski's advice.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: gas in oil
    Yep, I agree with dkozloski and ranger, as usual. If you don't want to turn it over with the plugs out, at least take them out and look in the cylinders. One of them will have liquid gasoline in it. Replace the injector for that cylinder, or at least get it out of there and clean it or have it cleaned. You might also want to replace the fuel filter, in case the filter itself has been breached and let a bunch of crud through that led to your stuck injector. If you haven't had the fuel rail recall done yet, now might be the time to call the dealership.
    You will have to get the liquid fuel out of the cylinder before you try to start it again. Do dkozloski's procedure or siphon it out somehow, but don't try to turn it over with the spark plug back in there until you get the fluid out or you'll really be up a creek.
    Good luck... Let us know how it works out.
    Mike
    Feb 2004
    FL
    2,250
    Re: gas in oil
    Please don't use the starter. Put an appropriate wrench on the harmonic balancer bolt, and turn the engine that way. It should spin pretty freely without plugs. Otherwise, you need to disconnect the coil pack power connector, or else you'll get nasty sparks, and sparks don't like gasoline much. Then, I'd still be a bit worried about the starter solenoid.... Either way, be careful.
  11. Remove Advertisements
