Check engine light
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Check engine light in Cadillac Engine Discussion; 1998 Cadillac DeVille Northstar. Check engine light came on today while driving. I checked codes and came up with PO300 ...
    csbeard is offline Cadillac Owners Member
    Feb 2004
    14
    Check engine light
    I checked codes and came up with PO300 (Engine misfire detected)
    Before I take it to the shop, is their anything I can do.
    Like fule injection cleaner in the fule tank??
    Thanks
    CSBeard
    68
    82,048
    Re: Check engine light
    Change wires and/or plugs. Stick with OEM.
