EGR Trouble HELP???
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, EGR Trouble HELP??? in Cadillac Engine Discussion; I'm trying to replace the EGR in my 95 Eldo. The fuel rail has a bracket looking object that loops ...
    Dejavu0187 is offline Cadillac Owners Member
    Automobile(s): 87 Deville 4100, 95 Eldo
    Feb 2005
    Orlando
    14
    EGR Trouble HELP???
    I'm trying to replace the EGR in my 95 Eldo. The fuel rail has a bracket looking object that loops under one of the EGR nut-bolts. How do I get the EGR off with this in my way, the fuel line seems stationary so its cant lift over the bolt. Don't make fun of me , just HELP. Thanx
    69
    82,386
    Re: EGR Trouble HELP???
    If your fuel rail is original (nylon) then there is enough flex in it to move it slightly. If it has been replaced under the recall with the stainless steel rail, then the entire rail needs to be removed. I think that is what you are asking.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    You have to take the nut off and remove the bracket then remove the bolt that holds the EGR valve down. The bolt that holds the EGR is a stud headed bolt that has a nut on it to hold the bracket. That bracket is actually a shield to keep the fuel lines away from the EGR in the event the items might get crushed together somehow so you really want to reinstall it even though it is a bit of a pain.
