Now what do I do? Northstar block casting porosity - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Like Tree3Likes
Northstar Engines and System Technical Discussion Discussion, Now what do I do? Northstar block casting porosity in Cadillac Engine Discussion; Here's a tip when working with threaded fasteners and various epoxies - either liquid or the various pastes thickened with ...
  1. #16
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: Now what do I do? Northstar block casting porosity
    Here's a tip when working with threaded fasteners and various epoxies - either liquid or the various pastes thickened with silica, metal dust, or microballoons ............ If you want to refresh or create new threads using epoxy paste, go ahead and patch/partially fill your damaged hole. Thoroughly wax and wipe off the fastener threads and an inch or so of the shank - Simoniz seems to work best. Thread the fastener into the epoxied hole and let it cure. Once the epoxy has completely cured the fastener will unscrew out of the perfectly formed threads in the epoxy. Clean the fastener threads with lacquer thinner before using a thread locker.
  2. #17
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    WHOOOHOOOO!
    Its all back together and slung to the lift ready to go in…. but what’s this? 2 broken wires I discovered while de-greasing the engine compartment. Must have happened when I pulled the engine. The wires I refer to are quite small and connect to the “Vehicle Speed Sensor”, located on the A/T’s Final drive snout.
    My question is:
    Are the broken wires a resistant type that the entire length must be replaced or can I simply splice them back together and be good to go?
    CadillacLuke24 likes this.
  3. #18
    68
    81,917
    I think they are just wires and you can splice them.
  5. #19
    83CADMAN's Avatar
    Jun 2009
    Pacific Northwest
    62
    467
    That’s what I’m hoping Ranger. A little solder and some heat shrink.
    I would be willing to guess those little buggers route thru the main harness to the PCM.
  6. #20
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    Good work! Let's see her in all her glory when you're got everything back together!
  7. #21
    rbb
    rbb is offline Cadillac Owners Member
    Automobile(s): Pontiac Bonneville GXP
    Jan 2013
    Edmonton
    38
    3
    I had a similar problem on my '05 engine swap, except I caught it before they snapped. Those wires run through the harness you may need to spend several hours trying to find any shorts caused by pinched wires and then using high-heat resistant electrical tape to repair the damage. Or spend $1327 on a new harness from www.newgmparts.com the short I had caused the ignition system fuse to blow whenever it drove a certain speed causing the car to stall while driving.
  8. Remove Advertisements
