Little green hoses
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Little green hoses in Cadillac Engine Discussion; My '93 Eldo has 104,000 miles on it and I am doing a lot of routine maintenance on it at ...
    Jimbad is offline Cadillac Owners Member
    Automobile(s): 1993 ETC, 2000 DHS
    Jan 2005
    Derwood, MD
    78
    59
    Little green hoses
    My '93 Eldo has 104,000 miles on it and I am doing a lot of routine maintenance on it at this point. Should I replace the little, high-temp green hose(s) as a preventative measure. Do they go bad?
    Thanks, Jim
    68
    81,926
    Re: Little green hoses
    I believe that is a silicone hose and is supposed to last a long time. I hope so because it looks like a bitch to get at. If the TB is off I'd replace it. If not, I wouldn't touch it til I absolutely had to.
    LCLCLC is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville
    Mar 2004
    244
    I've learned on here those are high temperature silicone hoses.
    Do not replace them with regular heater hose, even though they are expensive, compared to regular hose. Regular hose will fail quickly because they are located in places that have a lot of heat from the motor.
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    As noted above, the two short green heater hoses are silicone, to be able to withstand the high heat in a small area, located right next to the metal EGR pipe.
    These hoses will normally outlast the car. Just check the four (4) screw clamps for tightness. The hoses can leak when under high engine RPM, and appear fine when at idle or low RPM.
    -George
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    I thought this was a thread about a John Mellencamp song.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    LOL Katshot!
    Mike
    Jan 2005
    Derwood, MD
    78
    59
    Thanks for the replies to my question. I was hoping that the answer was "don't touch them" because they are extremely difficult to reach.
    Jim
  10. Remove Advertisements
