P 0300 random misfire - 2000 STS
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, P 0300 random misfire - 2000 STS in Cadillac Engine Technical Discussion; I have a random miss fire, i reaplaced plugs a coil packs two months ago. It doesnt seem to be ...
    J2000ssts is offline Cadillac Owners Member
    Automobile(s): 2000 STS, 135,000 miles
    Mar 2013
    9
    I have a random miss fire, i reaplaced plugs a coil packs two months ago. It doesnt seem to be a leak on the intake, egr its fine. Could it the problem be in the exhaust system?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    3,377
    Year make model? How many miles? Have you done a tune up?
    Mar 2013
    9
    2000 seville sts 135000 miles ,yes like two months ago
  5. #4
    1BadCadSTS's Avatar
    Nov 2010
    3,377
    No intake leaks? Coils all good? Change the serp belt.
  6. #5
    Mar 2013
    9
    I got two stripped plugs in cylinders 6 and 8 , now what how can i fix that
  7. #6
    Submariner409's Avatar
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    74
    41,569
    Re: Pcm po300 random misfire
    This thread has nothing to do with "PCM Tuning". Moved to Northstar Performance.
    Stripped plugs in 2 cylinders = new cylinder head OR a very, very lucky expert thread repair job by an awfully good shop. In a perverse way, you're "lucky" the bad plug threads are in the left (front) head.
    ALWAYS place your car model and year in your profile. It sure makes diagnosis easier - due to radical differences in models/engines/years/parts.
  8. #7
    Automobile(s): White Diamond '03 DHS (with floor shift)
    66
    70,368
    Re: P 0300 random misfire - 2000 STS
    Might look into Helicoil. They make thread repair kits for spark plug threads. Front side should be easy access.
    http://www.helicoil.in/
  9. #8
    Mar 2013
    9
    Thanks, i took the car in to the shop. No striped plugs but the front ignition coil got replaced. They told me that the rear coil needs to be replaced. Well i ran the car for a week than abs and brake ligth and ttc came on .pulled the codes abs c1277 c1298 pcm p1571 p1644 and pcm u1040. I wonder if that rear ignition coil is making this codes pop up. When they come on the steering is hard and it feels like the car looses alot of power. Can some one help?
  10. #9
    66
    70,368
    Without their definitions, codes are just numbers.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
