3 more radiator queries
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 3 more radiator queries in Cadillac Engine Discussion; 1) Do I disconnect the lower hose from the radiator or the block? 2) Does it matter? 3) During the ...
    Jimbad is offline Cadillac Owners Member
    Automobile(s): 1993 ETC, 2000 DHS
    Jan 2005
    Derwood, MD
    78
    59
    2) Does it matter?
    3) During the drain process should I take the thermostat out?
    Thanks, Jim
    (If this is a repeat of an earlier post I apologize.)
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: 3 more radiator queries
    take it off of whichever one is easiest, don't bother taking out the thermostat, and REMEMBER to put the BARS LEAKS supplement in the hose, not in the surge tank. Very important! Also, if its on the 93, use the green coolant, mixed 50/50, if its on the DHS use DEXCOOL, also mixed 50/50.
    Jan 2005
    Derwood, MD
    78
    59
    Thanks, Spyder.
