Motor mount help needed!
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Motor mount help needed! in Cadillac Engine Discussion; My 99 STS with 38K miles clunks every time I let off the gas and get back on it. Or ...
    Rick99STS is offline Cadillac Owners Fanatic
    Nov 2003
    55
    217
    My 99 STS with 38K miles clunks every time I let off the gas and get back on it. Or when I shift into or out of gear. I'm guessing its a motor mount, in fact, the dealer just told me that motor mounts are pretty common on my car. Anyone replaced one themselves? Hard to get to? Whats the dealer charge? Anyone?
    cadillactech is offline BAD EMAIL ADDRESS
    Jan 2005
    over on the south 40
    154
    Re: Motor mount help needed!
    They are pretty tough to change on the ground. Our shop usually gets about 2.0 hrs to change one ( if it's the front, and it usually is )
    32V_DOHC is offline Cadillac Owners Member
    Feb 2003
    46
    You will need to remove the fans and the plastic sheild under the nose. Get new clips for the sheild because the old one tend to loosen up when removed and allow the sheild to rattle. Once the fans are out, remove the motor mount nuts from the frame. Then support the engine and remove the bracket mount bolts from the head. Then loosen and remove the nuts that hold the motor mount to the bracket. Finally remove the lower bracket bolts that go into the block. Lift the engine slightly until the mount can be pulled free. Install new mount and bolt bracket back to block and head. Install nuts on mount to bracket. Lower engine and install nuts to frame. Torque to spec. Reinstall cooling fans and sheild. 2 hrs at the dealer is probably reasonable. You could probably do it yourself in 2-3 hrs.
    HTH
    John
