trans code
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, trans code in Cadillac Engine Discussion; can anyone shed some light on the code po56? what does it mean,how to correct it and does it affect ...
    eldog90's Avatar
    eldog90 is offline Cadillac Owners Member
    Automobile(s): 1996 deville
    Jul 2003
    ohio
    57
    67
    trans code
    can anyone shed some light on the code po56? what does it mean,how to correct it and does it affect thr driveabilty of the car?how major or minor is this code.the car is a 95 sls with 116,000 on the clock
    32V_DOHC is offline Cadillac Owners Member
    Feb 2003
    46
    Re: trans code
    Test conditions
    1. Codes p024, p075, and p091 NOT set
    2. Trans not in neutral or park
    3. engine running.
    4. vehicle speed greater than 10 MPH
    Failure condition
    1. Input shaft speed 50 RPM or less for 2 seconds.
    Action taken
    1. Turn on SES lamp
    2. PCM calculates input speed based on output speed and gear ratio.
    3. PCM calculates slip speed using calculated input speed.
    4. TCC engaged
    5. garage shift adapts frozen at current level
    6. shift adapts frozen at current level
    7. Torque management disabled.
    HTH
    John
    Feb 2003
    46
    Re: trans code
    To diagnose
    WIth engine running and trans in park check PD72
    If greater than 100 rpm the fault is not present check for EMI sources near wiring and wait for fault to reappear
    If less than 100 RPM then turn engine off and disconnect trans connector. Measure frequency between a and b pins on trans with engine running and in park.
    0 hz then check wiring in trans. If no problems found then replace inupt sensor.
    Not 0 hz then turn engine of and reconnect connector. Back probe terminals 1b3 and 1b4 at PCM
    0 hz then repair wiring between trans and pcm.
    not 0 hz then inspect terminals 1b3 and 1b4. If ok then replace PCM.
    The sensor was a common failure point and a good bet if you can't perform the diagnosistic.
    HTH
    John
