Fixing Head Gasket
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Fixing Head Gasket in Cadillac Engine Discussion; I just got a 1999 Cadillac Seville STS. The only problem is that it needs a new Head Gasket. I ...
    Collin Taylor is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Seville STS
    Jun 2013
    Ypsilanti, MI
    25
    Fixing Head Gasket
    I just got a 1999 Cadillac Seville STS. The only problem is that it needs a new Head Gasket. I did some research and found this SureGrip Stud Kit. This kit looks like it could solve the head gasket issue for sure but i will have to find out. If anyone has some advice or tips for me that would be great. http://www.northstarperformance.com/sgstuds.php
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    550
    Re: Fixing Head Gasket
    Either timeserts, or better yet Norm's inserts, are also considered a 'permanant' repair. They can be installed with engine in car if you prefer (many still would rather remove engine from car anyway) whereas studs require engine removal.
    69
    82,162
    Yup, as mentioned, inserts work just as well. Choice is yours, but do your homework. A Northstar HG job is not a weekend project (for most people).
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Definitely get a Factory Service Manual or an Alldata subscription for your car while you complete the repair.
    Jun 2013
    Ypsilanti, MI
    25
    I am going to use alldata to help me. I also have a garage that i plan to work in so i can take my time and get it right. But i also at school for automotive so i have done several projects prior to this. I also wanted to know if i should drill and tap the holes if the treads are fine to maybe correct a future problem or just replace the gaskets.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    You ALWAYS drill and re-tap the North Star when replacing the head gaskets, ALWAYS
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    .............. X 3.
    For starters, and to get some idea of what you're up against, look through
    www.carrollcustomcadillac.com - www.huhnsolutions.com - www.northstarperformance.com
    .......... and, if you use inserts, you ALWAYS use a set of NEW GM head bolts and washers.
    Please - please - read the sticky thread ^^^ on Northstar head gasket work just above this thread. You're on a very steep learning curve, and you might just be in over your head. You WILL need a real GM/cadillac service manual to do the job properly - too many special procedures and torque values to fly blind. (I see you are subscribed to Alldata - that's fine.) Do you speak 3 timing chains, tensioner adjustment, timing, and oil pump drive friction ? Hydraulic cam follower buckets and water pump drive pulley removal - from the left bank intake cam ??
  11. Remove Advertisements
