02 sensor
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 02 sensor in Cadillac Engine Discussion; The o2 sensor on my 96 sts is bad. Its the one that is in the manifold at the front ...
    bravo366 is offline Cadillac Owners Member
    Sep 2004
    9
    02 sensor
    The o2 sensor on my 96 sts is bad. Its the one that is in the manifold at the front of the engine. The parts store didnt stock it and had to order this sensor, what would disconnecting the sensor and then running the engine do?
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: 02 sensor
    You might as well just leave it plugged in..... When they fail, it goes into failsafe mode... Id thikn itd be the same or worse by unplugging it...
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: 02 sensor
    Disconnecting the sensor won't hurt anything, but it won't solve any problems either. There's no reason to disconnect it. It might even set more codes that way, so if I was you I would just leave it and replace the sensor when the new one comes in.
    Good luck...
    Mike
    cart69's Avatar
    cart69 is offline Cadillac Owners Fanatic
    Automobile(s): 96STS engine only!! only thing left from my 96 after divorce
    Dec 2004
    Illinois
    37
    150
    Re: 02 sensor
    dont forget to tell how the install goes i need to replace my front o2 sensor too, looks like it will be fun!!! not really that bad but let me know i am waiting for it to warm up before i do it, to much snowmobiling right now!!
  7. Remove Advertisements
