Smell Coolant but from what?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Smell Coolant but from what? in Cadillac Engine Discussion; Just had radiator tanks replaced which was the source of a leak. Had the supplement added and all new DexCool. ...
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    I smell coolant and at nite in the light I can see some slight steam not noticeable in the day, from the driver side of the hood (side fender).
    I cant seem to see a leak, and I havent had to add coolant. Took car back to the radiator place and the guy briefly looked it over. He said maybe the heater core was going. I told him I dont see any steam on the windshield, nor is the smell eminating from inside the vehicle.
    He says to "keep an eye on it". No s#*t!!
    Question is, what is on the driver side of the engine that can be steaming?
    STS 310's Avatar
    Dec 2003
    LOS ANGELES CA
    1,489
    Re: Smell Coolant but from what?
    Ok I did a search on a thread that was similiar. RANGER mentioned something about the water pump gasket. Is this on the driver side of the car?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Go to the store and get some "Rit" clothes dye and add some to the coolant tank. It is harmless to the cooling system but will leave a residue where the coolant is coming out and evaporating. The leak will be easily traced. Don't get any on you.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Yes, the water pump gasket is on the driver side. I had to change mine, it was pretty simple. Before you spend money fixing anything else, try this. Use a hose, and spray down your engine compartment pretty well. By doing this, you should rid yourself of any lingering coolant, that spilled out, when your radiator was repaired. If you have coolant, pooled up near the exhaust, or any other hot parts, you will smell the coolant, for a long time. It doesn't seem to evaporate too easily. Give it a shot, and post back with the results.
    Don
    STS 310's Avatar
    Dec 2003
    LOS ANGELES CA
    1,489
    I was thinking the same thing, that when the rad was out, Im sure that some coolant got into some spots and that is what is I smell, the old coolant burning off.
    69
    82,262
    See my response to GATEDHD re: "Small Coolant Leak"
    STS 310's Avatar
    Dec 2003
    LOS ANGELES CA
    1,489
    Quote Originally Posted by Ranger
    Saw it. Thanks Ranger.
  10. Remove Advertisements
