5.3 motor
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, 5.3 motor in Cadillac Engine Discussion; Attachment 109745 Attachment 109737 think i can fit this in my car?...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    5.3 motor
    Attachment 109745Attachment 109737
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Re: 5.3 motor
    People that ask that question usually find one way or another. Sounds like a fun project.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Holy serpentine belt batman!
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    Re: 5.3 motor
    Is that the front wheel drive version from an Impala?
    If so, I would think it's possible.
    Aug 2007
    mpls mn
    2,527
    Yes, gp motor. Same thing. Trans went so seller swapped out mtr/trans. Has wire harness and computer. Size wise it would work fine but computer issues? No fun
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Re: 5.3 motor
    You need the transmission and the complete engine harness and ecm. The body harness for the gauges will not be needed per se' because you'll be using your existing ones. Unless the plugs are different......
    I think of swaps like that all the time........
    Aug 2007
    mpls mn
    2,527
    Used to think fwd LS motor was potentially more compact than NS. But after seeing accessory crap like alt and front mount wp I think not. I think the LS might actually be wider frt/ back? And there are those darn steel water lines coming from the wp. Is there any way GM can get rid of those tubes that rust out?
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    Re: 5.3 motor
    The tubes are cheap and cost effective for the life of the motor per se'.
    Heaven forbid the parts were made durable and didn't need replacement.
    How would they make any money......
  11. Remove Advertisements
