Cleared PCM codes - now emissions test not ready
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Cleared PCM codes - now emissions test not ready in Cadillac Engine Discussion; i did the onboard scan and scanned all codes and the cleared and reset all codes and they said that ...
    techx4965 is offline Cadillac Owners Member
    Automobile(s): 2003 deville
    Mar 2013
    36
    9
    i did the onboard scan and scanned all codes and the cleared and reset all codes and they said that this is reason odb emmison couldn't get a reading or battery unplugged i told them i cleared all and reset.....is there certain codes that cant be deleted the will affect odm data? and also how do i get the emissions odb info info back in the computer asap thank you for info they said something like a drive cycle i have a 2003 deville also say if i just scan the pcm and delete a code will that delete odm info or if i delete a dss code? instead of scanning all and clearing all info
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,924
    Re: reset my computer now emmisions test not ready? help
    Any time you "clear all codes" the system will need either a dedicated GM Drive Cycle or a week or so of normal commuting during which no P emissions fault occurs in order to set the necessary "system ready" flags for the emissions test set. There's no need to ever "clear codes" - the system will automatically delete codes which do not again set after a specific number of successful start-run (not "drive") cycles.
    If your car has a permanent or recurring P emissions code it will never pass emissions testing - until you diagnose and repair the problem that sets the code(s).
    This is not the forum for normal PCM reset and car operation questions. Moved to Northstar Performance.
