Do not stud a Northstar - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 52
Like Tree14Likes
Northstar Engines and System Technical Discussion Discussion, Do not stud a Northstar in Cadillac Engine Discussion; I have been a GM trained Cadillac Tech since 2003. 6 years of that I was at a standalone Caddy ...
  1. #31
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Do not stud a Northstar
    I have been a GM trained Cadillac Tech since 2003. 6 years of that I was at a standalone Caddy dealer.
    I have misspoken here. The OE bolts are not Torque to Yeild. I have posted this on the forum many times since 2007. OE Northstar bolts are reusable per GM's documents, but you need to clean the bolts, reapply the threadlocker, and apply sealer to the washer to keep fluid out of the bolt holes.
    I have use the GM big serts 1 time and I have to plans on ever doing that again. I have used the NS300L inserts and feel they are the best choice.
  2. #32
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    FWIW ............
    Tim Carroll is a Northstar repair mechanic and operates a shop in Texas. He has a vested interest in engine studs.
    AJ is/was a Cadillac Tech who also does engine and PCM work on the side.
    Neither of these businessmen is currently an authorized vendor in CF, so plan your communications accordingly.
    ........ and here's a BIG quote from the 2002 GM/Cadillac service manual:
    Engine overhaul, cylinder head bolts ......... procedures -
    Left bank cylinder head ........ (italics mine)
    Removal:
    4. Remove and discard the ten M11 internal drive cylinder head bolts.
    Installation:
    2. Make sure any old thread sealant material is removed from the cylinder head bolt holes in the block (Is this the source of AJ's advice ?)
    5. Place the cylinder head on the deck face
    IMPORTANT: Do NOT reuse the old M11 cylinder head bolts......
    6. Install new M11 cylinder head bolts in the head."
    I have not found the TSB that reverses this procedure i.e. - Use the head bolts over again - and my TSB list dates back from 01/28/13.
  3. #33
    Carroll Cadillac is offline Banned
    Automobile(s): '00 SLS, '65 CoupeDev, '96Dev, '89Eldo, '01DTS, etc...
    Jul 2010
    Ridgefield, WA
    31
    Jim,
    You left out Tim has been an engineer for over 27years!
    Just a tad more then an average mega shop owner.
    I need to speak to you, I am going to Pm you,
  5. #34
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by Submariner409 View Post
    FWIW ............
    Removal:
    Installation:
    You are correct and you need to go back to the original training manuals to find the information. The bolt part number did not change
    Now the Felpro and Engine tech bolts state that they are Torque to yield bolts.
    The OE bolts per GM are not Torque to Yield.
    I recommend replacing the bolts every time
  6. #35
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    People have been studding engines since the beginning of high performance building ( including aluminum block engines since 1990 in the old DOHC 349 Cubic Inch in the Corvette ZR-1). any time a real mechanic puts real horsepower in an engine one of the very first things done is studding.
    Tim i know our companies dont have the greatest terms but you have to agree that studs are the only way to go, especially in these northstars.
  7. #36
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    This is for the service manual and as you can see when a torque to yeild bolt is use GM calls it out
    Notice: Powdered metal connecting rods have rod bolts which yield when torqued. If the rod bolts are loosened or removed the rod bolts must be replaced. Rod bolts that are not replaced will not torque to the correct clamp load and can lead to serious engine damage.
    another time
     6. Remove the water pump pulley bolts.
    Caution: This vehicle is equipped with torque-to-yield or single use fasteners. Install a NEW torque-to-yield or single use fastener when installing this component. Failure to replace the torque-to-yield or single use fastener could cause damage to the vehicle or component.
    and another time
    Note: Front end alignment not required due to frame only being lowered and reinstalled.
    18. Install NEW frame-to-body bolts (1) and tighten to 110 Y (81 lb ft) + 90 degrees.
    and another one that I see very often whe chaning the water pump on a Cruze
     1. Install the engine mount bracket (2).
    Caution: Refer to Fastener Caution.
    Caution: Refer to Torque-to-Yield Fastener Caution.
     2. Install the 3 NEW engine mount bracket bolts (1) and tighten to  60 Y (45 lb ft) + 45–60°.
    and then another 3
     4. Install the 3 NEW engine mount to engine mount bracket bolts (3) and the 3 washers (4).
     5. Tighten the 2 engine mount to body bolts (2) and the engine mount nut (1) to  62 Y (46 lb ft).
     6. Tighten the 3 engine mount to engine mount bracket bolts (3) to  50 Y (37 lb ft) + 60–70
    as you can see they all state Torque to Yield and the Northstar Head bolts do not
  8. #37
    Oct 2012
    Manitoba, Canada
    376
    the thing i dont understand is why people drop the sub-frames on these vehicles, it is so much easier out the top! me alone takes about 4 hours, jakes best is little over 2 and together we have done it in under 2 hours, there is no risk of any alignment/ rusty body bolt issues that may occur.
    98eldo32v, 98eldo32v and Pht like this.
  9. #38
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    it takes 45 minutes to 1 hour to drop it out the bottum
    This is the R&R time for the cradle
    E1707 Frame, Engine - Complete - Replace
    Effective Date: May 1, 2013
    LABOR CODE: E1707
    Note: For alignment times, refer to labor code E2000/8070012 and add the applicable base time to base labor hours.
    Base LABOR TIME: 1.8
    J1000 Pan And/Or Gasket, Oil - Replace
    LABOR CODE: J1000
    Note: For steering wheel angle and/or front toe adjustment times, refer to labor code E2000/8070012 and add the applicable base times to base labor hours.
    Base LABOR TIME: 4.5
    To Clean Parts On Vehicles Over 30,000 Miles/48,000 Kilometers ADD TIME: 0.1-0.3
    With SAI ADD TIME: 0.2
    J1190 Lower Crankcase Seal/Sealant Replacement
    LABOR CODE: J1190
    Base LABOR TIME: 11.8
    To Recover and Recharge A/C System ADD TIME: 0.3
    J1840 Engine, Universal - Replace
    LABOR CODE: J1840
    Note: Goodwrench Engine.
    Base LABOR TIME: 10.7
    This is remove the old damaged cradle and transfer part to a new cradle and then reinstall it
    LABOR CODE: E1707
  10. #39
    Oct 2012
    Manitoba, Canada
    376
    but these cars are not new anymore, alot have rust!, what happens when the nuts from the sub frame bolts spin inside the body? there goes at least 2-4 hours of your time.
    the entire job takes us about 16 Hours,remove, clean and re-seal, with drilling and tapping installing studs, and re-assembly of the engine, and re-install.
  11. #40
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Quote Originally Posted by 04GrandAmGT View Post
    oh god... I'm not alone! Someone else has experienced it! I had this happen to me one time - it was a real treat. The cage around the captive nut pretty much disappeared as soon as the bolt was turned. I fear this every time I touch a fwd GM subframe now, though it hasn't happened again.
  12. #41
    Oct 2012
    Manitoba, Canada
    376
    with how rusty cars get especially the north eastern USA and Canada is really bad for it, and taking it through the top is so much faster its not even funny
    98eldo32v and 98eldo32v like this.
  13. #42
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    CCC pulls em out the top also
  14. #43
    Jul 2010
    Ridgefield, WA
    31
    Yes I do agree! If we agree on one thing it is this, there is no other repair beside studs, and if anyone believes otherwise then they have an extreme lack of
    knowledge of the Northstar.
  15. #44
    Speedygman is online now Cadillac Owners Fanatic
    Automobile(s): NorthStar 32 Vicky/ 58 CHEVY BROOKWOOD 348, 1983 Manta RX7
    Mar 2011
    Juliette Ga.
    74
    164
    Very well said.
  16. #45
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Northstar Engine Mechanical System 16014.11.1 dated 1993 does not state that you need to replace the head bolts or the rod bolts.
    I have version 16014.11.2 at home. I will look at that copy.
    I do not see an advatage to studs over the NL300 inserts. The inserts use the OE bolts.
  17. Remove Advertisements
