Drilling and Tapping The Northstar V8......my personal experience so far. - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 67
Like Tree22Likes
Northstar Engines and System Technical Discussion Discussion, Drilling and Tapping The Northstar V8......my personal experience so far. in Cadillac Engine Discussion; Let there be studs.........
  1. #16
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: Drilling and Tapping The Northstar V8......my personal experience so far.
  2. #17
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Well,
    The rear bank of studs are installed at 4" above the surface with thread locker. They'll need a tweak.
    Have to set the front.......
  3. #18
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    What is in upper right corner of pic? Can't see clearly. Looks like Honda motor?
  5. #19
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Sure is......
  6. #20
    Aug 2007
    mpls mn
    2,528
    My iPad crops the pics. I used my computer to look at pic and it is much larger.
  7. #21
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Front studs have been thread locked.
    I have to tweak a couple to get the gasket and the heads on. I've got to get in the groove with this thing. Yet, have to pay some bills.
  8. #22
    daveyhouse is offline Cadillac Owners Fanatic
    Automobile(s): 98 deville D'Elegance 86 Fiero 2m4 / 86 Fiero GT W/SBC
    Jun 2012
    York, Pa
    234
    I used a little plastic mini square (3") that came with my compound miter saw to check for squareness with the deck. I also used wooden foot ruler to check for proper exposure of stud above deck.
    I then had a handle that came with a small hydraulic jack that was big enough to fit over the stud to tweak it in the direction needed. I put an old shirt over the stud to help protect the threads then applied pressure. Don't beat on it, just push.
    98eldo32v and 98eldo32v like this.
  9. #23
    Aug 2007
    mpls mn
    2,528
    we all know studs are straight. does that mean you are drilling and tapping the holes at an angle? not that it makes any difference when heads are on
  10. #24
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    @ Stoveguy,
    I can only say that now that the studs are in and the drilling complete, the ones that need tweaking must be slightly off since drilling by hand WITHOUT a guide componet/device. I call this human error.
    Yes, the studs are supposed to be straight also, but nothing in life is perfect. A slight tweak here and there won't be bad.
  11. #25
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by 98eldo32v View Post
    @ Stoveguy,
    If they're not straight then won't that give ur head bolts "Play" under load
    I believe the whole objective is to Prevent Stripping of the threads and holes... That's what causes the separation of the blocks in the first place, right?
    So if u drilled at an angle, u essentially created the very problem u were trying to fix
    But I not exactly sure if that is the case with studs
    Would like to know more on this so please keep up the updates
  12. #26
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,215
    SUPER_LAC, The studs are threaded into the block and, once in, they are not turned (like, tightened) ever again. The fine threads and upper nuts do the torquing - not the lower threads; they aren't even tightened into the block - finger tight with thread locker. IF a stud hole is drilled and threaded a few thousandths of an inch off the stud then needs to be tweaked in the correct direction to get it perfectly perpendicular to the deck face. A stud can be "bent" (that's a scary term, here) a tiny bit to allow the head to smoothly drop over all 10.......... but if you had to bend the stud enough that you could see the angle at the lower thread area, then you have problems - big problems.
    To further bend your mind, consider that original head bolts do not go all the way to the bottom of the block hole/threads - the only thing that holds those bolts in is the torque applied to clamp the head to the block - the bolts don't even come close to bottoming in the holes.
  13. #27
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by Submariner409 View Post
    Oh ok!!!
    I get that now
    I was thinking the studs did all the tightening
    Thanks for that clarification !!!
    Sent from AutoGuide.com Free App
  14. #28
    Aug 2007
    mpls mn
    2,528
    You lay stud on flat table and roll them. They don't look like a banana? Do they?
  15. #29
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by stoveguyy View Post
    I will have to buy a kit one day!
    Did everything work good tho?
  16. #30
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Well,
    A 12" x 3/4 pipe and a few pushes in different directions later, the headgaskets slid over the studs.
    Now, it's getting the heads on.......
  17. Remove Advertisements
