Results 1 to 1 of 1
Thread: ABS - Traction Control
    outlaw1369 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado 1996 Sedan Deville
    Aug 2004
    New York
    57
    Having a issue with the ABS box located in front of the engine under the water pump. It seems that the cover for the box has been missing since I purchased the car. The ABS and Traction Control lights have been on the whole time also. Upon inspection the wiring harness for the abs had some water sitting on the connector causing the harness to corrode. Is there a common fix?
    Last edited by outlaw1369; 01-10-05 at 03:30 PM. Reason: Should be in the suspension brakes section - please delete post.
  • You may not post replies
