2000 Deville Base - Front Ground Wire
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 2000 Deville Base - Front Ground Wire in Cadillac Engine Discussion; So a couple of days ago I could'nt get my car to start. I checked a bunch of things, but ...
    vctrfs is offline Cadillac Owners Member
    Automobile(s): 2000 Deville Base
    Feb 2013
    33
    37
    So a couple of days ago I could'nt get my car to start. I checked a bunch of things, but forgot about the ground wire and I wound up replacing my starter and intake gaskets. I guess on the plus side, it was a repair that was kinda needed, since my started looked horribad and would've went more sooner than later.
    But that wasn't my problem. On the front(left side) of my car, there is a wire that is not touching the ground(ground wire). I did some searching on ebay and found this and ordered it
    http://www.ebay.com/itm/271067618294...84.m1497.l2649
    I thought the ground on my deville lead from the alternator to the ground, but the guy says that this wire is for the engine to the ground. I am not 100% sure where these wires lead up to. I am kinda an amatuer mechanic in a way, but would this be a really hard job to replace? And is this the correct wire?
    If not, can someone point me where I can buy the correct one on eBay? Also, if anyone knows a good video or thread that can help me replace this wire, I would be really greatful. Thanks.
    Feb 2013
    33
    37
    Re: 2000 Deville Base - Front Ground Wire
    Bump! I can really use the help!
    Feb 2013
    33
    37
    Bump
  5. #4
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    544
    I replaced that ground wire on my 05 Deville. It ran from the alternator case, which is essentially the same potential as the engine, to the frame directly below the fuse box on the passenger side. Any 12" or so cable with the proper lugs on the end will work. Which end is disconnected? The alternator side is tough to get at.
  6. #5
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,718
    I'm no expert, but from what I know on my 96 DeVille that cable runs from the battery to some point on the engine. I want to say alternator, but do not quote me on that.
    Do you have a picture you could show us? that would help a lot.
  7. #6
    rodnok01's Avatar
    Feb 2012
    NC
    6,591
    Kind of confusing what wire you're talking about, but you need a wire to engine from battery, battery to body and engine to body. Doesn't really matter where you hook them to on engine.
  8. Remove Advertisements
