fuel injectors,1993 4.6 northstar VIn Y
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, fuel injectors,1993 4.6 northstar VIn Y in Cadillac Engine Discussion; what is best way to clean injectors while they are out? and how many ohms when doing ohm test. thank ...
    jwforce's Avatar
    jwforce is offline Cadillac Owners Member
    Automobile(s): eldoado
    Jan 2013
    46
    1
    what is best way to clean injectors while they are out? and how many ohms when doing ohm test. thank you..
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,600
    Re: fuel injectors,1993 4.6 northstar VIn Y
    About 13 - 14 Ω.
    Injector test bench and cleaner.
    Otherwise, install them, set up the engine for normal operation, pour a 20 oz. jug of Chevron TECHRON in the fuel tank and fill with a 93 octane Top Tier gasoline. Go for a long drive, including some aggressive "engine exercise' with its high power demands and fuel flow rates = Clean fuel system.
    Google "top tier gasoline" and "chevron techron" for background info.
