my STS...its a miracle!
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, my STS...its a miracle! in Cadillac Engine Discussion; My 97 sts is at 153,000 , an has been running not hot but a lot warmer than I like. ...
    sts20 is offline Cadillac Owners Member
    Automobile(s): 97 STS on 20,s
    Mar 2013
    anderson, south Carolina
    10
    My 97 sts is at 153,000 , an has been running not hot but a lot warmer than I like. I just redone the fuel pump,Water pump,hoses,thermostat,an starter all within the last month after six months of sittin... An this morning I realized I have been losing all my coolant this long , an discovered my bottom metal radiator hose on right was all tha way loose ...I felt like slappin myself @ the same time hittin my knees an thanking GOD....its 90 f 2day an so far so good
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Loosing coolant? So u got a low coolant message? If u say ur cooling system was low and that's why u were running hot and now hope a leaky radiator hose is the reason for yours issues than lets run with that.
