How to clean out fuel system in a 96 Eldorado sitting for 6 years. - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Like Tree2Likes
Northstar Engines and System Technical Discussion Discussion, How to clean out fuel system in a 96 Eldorado sitting for 6 years. in Cadillac Engine Discussion; WOW! Never seen anything like that before. I would bet it could be salvaged, but a new pump isn't that ...
  1. #16
    68
    81,768
    Re: How to clean out fuel system in a 96 Eldorado sitting for 6 years.
    I would bet it could be salvaged, but a new pump isn't that expensive and since it's already down, what the hell.
    P.S.
    Perfect example of why hearing the pump run means nothing without a pressure test.
  2. #17
    NAES is offline Cadillac Owners Member
    Automobile(s): 1997 Eldorado
    Feb 2013
    28
    I thought about salvaging the pump but a foot of Gates brand submersible fuel line is $30 at Oreilly auto parts. I found the fuel pump on Ebay for $40 NIB!! How could I go wrong? I'll still keep the old pump for possible parts down the road but since it's already this far down, I might as well do it.
    And yes, the old pump runs fine but that doesn't mean a damned thing as far as getting the thing to run!
    NAES
  3. #18
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,594
    Fuel pump only for $40 or assembly for $40 - the last "$50 fuel pump assembly" we saw in here from eBay was Chinese and would not fit............ and "fuel pump only" may not have that flex line - thus the advice to look in RockAuto for the deals on original GM parts.
  5. #19
    Feb 2013
    28
    The listing was for an Airtex Fuel Pump Assembly part number 3935m. Airtex isn't the worst brand in the world.
    A quick search showed that it is in fact the entire assembly, not just the pump. I may have gotten lucky, if not I'll return it. The car hasn't run in a long, long time, what's another week or 2 going to hurt?
    I'm sure you're just looking out for my best interest. NAES
  6. #20
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Where did you get that part number?
    my listings show E3913M as the Airtex part number for a 1996 eldorado
  7. #21
    Feb 2013
    28
    Sorry Chris that was totally my bad. The car was manufactured 9/96 and sold as a 97. I see now that 96-7 is a transitional year for the fuel pump. I didn't know that until I did a little digging today. So my guess is that I'll end up getting a 97 pump that truly fits the 97 manufactured year. The Airtex comes with the wiring harness so if the pump physically fits the tank then I'll play with the harness a little bit and see if it'll work. I don't see why not as they are both 4 pin connectors just arranged in a different plug..........I hope!
    Wish me luck guys. I'll report back when I get the pump and start messing with it.
    NAES
  8. #22
    Feb 2006
    55,594
    Re: How to clean out fuel system in a 97 Eldorado sitting for 6 years. (edited)
    FWIW, The 1997 "model year" (or ANY OTHER model year) began/begins in about August/YR. My "2002" Seville series was built from 08/01 to 06/02.
    Mid-summer is the production line reconfiguration time for the new model year. The onboard diagnostics (OBD) systems changed during 1995-1996.
  9. #23
    Sep 2007
    Wilmington, NC
    13,986
    and the 10th digit of the VIN will tell you the model year
  10. #24
    Feb 2013
    28
    SHE LIVES!!!!!!!................well sorta!
    I swapped in the new pump and primed the system a few times. Depressed the fuel pressure relief valve to ensure I'm at least getting fuel up to the engine and let her rip! She fired after a couple of cranks and then settled in. I only let it run for about 2-3 minutes as I haven't changed the coolant yet and didn't want to get the engine too warm letting that old stuff circulate.
    So next time around is some fresh Dex-cool and then I'll let her warm up and see how she feels. It's so awesome to get into a project that you know nothing about and be able to make your way through it. I want to thank all of you who replied and helped me out. It made the job so much easier.
    I'll report back after the coolant swap. Anything else I should think about getting while I'm already in there?
    NAES
  11. #25
    68
    81,768
    Just drain and refill with 50/50 Dex and distilled water.
  12. #26
    Feb 2013
    28
    Hey all I'm back.
    I took the Eldo to the (semi)-local Northstar "expert" for a once over. My list was tightening the front pulley to spec, fix the P300 code (engine miss firing), valve cover gaskets, plugs, wires, AC recharge and a general tuning for smog.
    The 3 day job turned in to 2 weeks with no phone calls getting returned. I finally had the time to just drop by and get the car. It was in the bay and literally nothing had been done on it. He breezed through every reason in the book for not getting the job done or returning my calls. 2 weeks wasted. Still misses at idle so I put a new set of AC Delco plugs in gapped at 0.60 and wires are on the way from RockAuto. Still misses so I'm hoping it's the wires. Otherwise I'll go through the coil packs and see which one(s) might be bad.
    The saga continues...............NAES
  13. Remove Advertisements
