low oil pressure-'97 SLS
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, low oil pressure-'97 SLS in Cadillac Engine Discussion; I've got a fairly low mileage (88k) Seville that has the oil press lamp blinking at hot idle. Give it ...
    Harry Yarnell is online now Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    73
    903
    I've got a fairly low mileage (88k) Seville that has the oil press lamp blinking at hot idle. Give it some rpm's (~1,000) and it goes out. No noises are apparent.
    The other day as I was pulling in my driveway, the STOP ENGINE message came up, as was the oil lamp lit. Again, no odd noises and the oil is full.
    I'm suspecting a bad sender. I could put a gauge on it, but it's buried behing the front motor mount.
    The question I ask is; is there any history of these senders going bad and/or the oil pump being problematic?
    The Seville doesn't have an oil pressure gauge on the DIC.
    Sure hope it isn't a bearing.
    69
    82,383
    Re: low oil pressure-'97 SLS
    Oil pumps are VERY reliable. Your problem is somewhat common and is almost always the oil pressure switch. Be sure to replace it with an A/C Delco switch.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,143
    Look at the blown open oil pressure switch in my albums.
    If you want absolute, concrete, unambiguous peace of mind on cruise/idling oil pressure, go through the drill of removing the oil pressure sender, screw in a test gauge and drive the car until hot - not for 5 miles - 35 miles; record your pressures under all conditions. Now install a new pressure switch.
