Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Northstar exhaust
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,110
    Northstar exhaust
    HAVING A DEBATE ABOUT TRUE DUAL EXHAUST ( header to pipe straight back) and if the N* 4.6 WOULD HAVE BACK PRESSURE ISSUES AND CAUSE COMPUTER CONFLICTS.
    WITH ONE PIPE PER HEADER. HOW TOUCHY ARE THESE CARS.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: Northstar exhaust
    sOMETHING iS wRONG wITH yOUR cAPS lOCK.
    If you can fit the piping, sensors, cats and mufflers to the car (lots of luck) it will run just fine............ no performance gain because the little Northstar has all the pipe it needs as-is.
    Even fitting the larger CORSA cat-back to my STS made no difference in anything but sound except MAYBE, just maybe, up near WOT redline.
    Let's move this to the proper forum: Northstar Performance. The Lounge is more for non-specific chit-chat.
    Feb 2013
    Minnesota
    1,110
    Quote Originally Posted by Submariner409
    Thanks for that....(I win ). The debate was chit chat, but will in the future.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    true duals on a Northstar powered Caddy has been tried since 1993 -
    IF you could complete a true dual exhaust -
    and have no problems -
    YOU would be the FIRST -
  6. #5
    Feb 2013
    Minnesota
    1,110
    Quote Originally Posted by basscatt
    What type of problems? Code producing? Performance robbing?
  7. #6
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    Quote Originally Posted by BlueAngel#07 View Post
    My guess would be room. There isn't a whole lot to work with on these cars.
  8. #7
    May 2004
    35
    imo it can be done. i just replaced the head gaskets on my 98 sts and while i had it apart i looked for a dual exhaust solution.. it looks tight but i think you could do it... furthermore the front bank pipe runs into the downpipe at about an 85 degree angle which is clearly not great for flow and adds turbulence to the flow of the rear bank exhaust. i think if you found a dual inlet/outlet cat converter it would be ok... i will attempt it at some point... the major problem i see would be actually welding the new downpipe off the front bank crossover(at the correct angle)
    beyond the obvious 85 degree entrance of the crossover pipe, there is about 1 inch if pipe protruding into the exhaust stream of the downpipe... scroll down to see the pic
    http://www.carrollcustomcadillac.com...eupgrades.aspx
  9. #8
    RandyT. is offline Cadillac Owners Member
    Automobile(s): Aurora
    Oct 2012
    13
    There is a member on the Aurora club with a Shelby engine in his Aurora that has true dual exhaust, I will see if I can find a thread about it. He could tell you more about any back pressure issues if any exist. I think one of the biggest killers is the exhaust manifolds, they have like a dual wall in them that takes up a lot of space on the inside of the exhaust, I have been trying to figure out a way to remove it, I have been considering cutting the manifold open, removing the guts, and then welding it back together. I have already cleaned my y flex pipe, I am waiting to install it with my 4.6 into my Aurora, I also have a hallowed catalytic convertor, it throws a code, but that should be fixed with my Madtuner tuned pcm.
  10. #9
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Shelby motor in FWD aurora? Shelby like ford?
  11. #10
    Oct 2012
    13
    No, it's from a Shelby Series 1, it's a car made by Shelby that used an Aurora V8.
  12. #11
    Aug 2007
    mpls mn
    2,527
    Did see a nice YouTube video of bare Shelby chassis. Had a ford motor though. Certainly not aurora style valve covers with center location plug wells.
  13. #12
    shelbyracing is offline Cadillac Owners Member
    Apr 2013
    28
    7
  14. #13
    Feb 2006
    56,868
    So you maintain that exhaust gas flow/pressure is the same under light load engine rev conditions as it is under maximum load WOT demands ?
    Do the same pressure test on a full-tilt dyno run and it will mean something.
    Sure wish the Seville had that much exhaust pipe tunnel width ...............
  15. #14
    Apr 2013
    28
    7
    Quote Originally Posted by Submariner409 View Post
    That's a good idea, I may do that and get some copper to plumb it into the car. Seville's have different tunnel width in rear? I would've thought that to be the same.
  16. #15
    Feb 2006
    56,868
    Here's Joe Tahoe's CORSA install as of last year. Not much room to spread out. Even worse up toward the resonator and Y/flex coupling. When I did my CORSA the car was up on a 4-point at the local AMJ Automotive - we looked long and hard at the room to work with, the little (279 c.i) Northstar engine, and the pipe ID's. The extra weight, cat(s), sensor(s), and labor was not worth the minimal gains in a FWD car with a non-programable PCM (1998-on). We're also screwed by the "crossunder" pipe arrangement coupled with the low under-engine ground clearance.
    Notice how Joe's Y-pipe area is off-center in the tunnel - that can be cured by using small screw band hose clamps on the muffler hanger rods: The front flex coupling allows you to move the entire system back and forth - center it, use a hose clamp against each side of the muffler hanger cookies, and BINGO ! - the exhaust system will not walk side-to-side.
  • You may not post replies
