Northstar Smoke On Startup - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Like Tree7Likes
Northstar Engines and System Technical Discussion Discussion, Northstar Smoke On Startup in Cadillac Engine Discussion; It's either coolant, oil or gas....
  1. #16
    69
    82,266
    Re: Northstar Smoke On Startup
  2. #17
    BONNEVILLEGXP's Avatar
    BONNEVILLEGXP is offline Cadillac Owners Member
    Automobile(s): Bonneville GXP
    Mar 2013
    Wichita Kansas
    22
    87
    Quote Originally Posted by Ranger
    Sorry but I had to. It's fuel, but I don't know what's causing it.
  3. #18
    69
    82,266
    Well, you said you could not tell what it was.
    If it's gas, it's one of two things. Either a ruptured FPR diaphragm (most likely) or a leaky/stuck open fuel injector (least likely).
  5. #19
    Mar 2013
    Wichita Kansas
    22
    87
    I have a fuel injector going out. I have to unplug it and tap it with a screw driver about once or twice a week. It does not make a healthy tick like the other 7 but makes a lose slap, so that's a good possibility. How would I check the fuel pressure regulator?
    Sorry I wrote in the thread that it's now clearly showing its smoke. I don't know my way around the forum 100% yet. Lol
  6. #20
    69
    82,266
    Just pull the vacuum line off the FPR at idle and look for gas at or leaking from the nipple. There should be none.
  7. #21
    Mar 2013
    Wichita Kansas
    22
    87
    Thanks, shall do!
  8. #22
    Mar 2013
    Wichita Kansas
    22
    87
    I checked the regulator and no gas is getting by. It's now blowing so much smoke out on startup that I can't backup tell it dissipates. I have tried to start it with the peddle to the floor (Most cars that's clear flood mode, not sure on N*) and it does not help. #1 Injector has been screwing up and makes the lose slapping noise, so I switched it #1 and the problem followed if. No question it's bad, but can it be bad enough to cause so much smoke that I can't even see behind me? I have a hard time seeing that if its that bad that it would still run smooth as silk after the 30sec rough startup. Sorry to bother you.
  9. #23
    69
    82,266
    Quote Originally Posted by BONNEVILLEGXP View Post
    Yes, that is clear flood mode, but if you have a stuck open injector, that won't help.
    I'd pull the fuel rail with the injectors attached. Have someone turn the key on to energize the fuel system and pressurize the fuel rail while you observe it. A leaky or stuck open injector will quickly reveal itself.
    Sure, if it dumps enough fuel it doesn't get burned and wets the plug so it doesn't fire and the gas gets pumped out as a thick mist (vapor). You are not doing your CAT or cylinder walls any good either.
  10. #24
    Mar 2013
    Wichita Kansas
    22
    87
    Once again, thanks! My common sense is still developing. Lol
  11. #25
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    All part of the game. You're doing tons better than the vast majority of auto owners
  12. Remove Advertisements
