HELP! 1999 SLS Coolant leak
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, HELP! 1999 SLS Coolant leak in Cadillac Engine Discussion; I'm a weekend mechanic... I had a coolant leak and was told that I should replace the water pump. I ...
    06204d is offline Cadillac Owners Member
    Automobile(s): SLS
    Nov 2009
    65
    6
    I'm a weekend mechanic... I had a coolant leak and was told that I should replace the water pump. I did (very easy installation). Now it appears that I have a leak further back (towards transmission). I crawled under car but could not find the source. Please advise what in this area would leak coolant and can a weekend mechanic repair it?
    69
    82,268
    Re: HELP! 1999 SLS Coolant leak
    Where "towards the transmission"? Between the engine and firewall? Or by the trans on the drivers side?
    Automobile(s): SLS
    Nov 2009
    65
    6
    If I had to guess, the way the fluid gathers, I would say by the transmission on drivers side
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Water crossover gasket(s) or heater circuit supply quick disconnect fitting. Maybe a leaking throttlebody heater coolant fitting - part of the coolant purge flow system pre-2000.
    www.alldatadiy.com
    Automobile(s): SLS
    Nov 2009
    65
    6
    Wow! Thanks. Is this labor intensive?
    69
    82,268
    Oohhh yeah! The crossover manifold that is. That said, the '99's are not known for it like the 2000+ engines.
    Automobile(s): SLS
    Nov 2009
    65
    6
    I'll check it out. Thank you guys for your help! Really appreciate it. After installing the new water pump, I thought I was home free. Oh, well...
  10. Remove Advertisements
