4.6L 32 valve water in oil
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 4.6L 32 valve water in oil in Cadillac Engine Discussion; OK, wifes eldorado overheated. Some bad signs of water in oil and exhaust puff coming out of radiator cap. I ...
    pixelpadre is offline Cadillac Owners Member
    Automobile(s): 1999 Eldorado
    Mar 2013
    64
    I took off the intake and their were pools of oil and water sitting on top of the engine. I noticed that there are a bunch of these round plug like caps scattered across the top of the engine. Not sure what they are but one of them is cracked along the side. I have a photo on my smart phone and will post it if necessary. Could the leak be coming from that or are these plugs not relevant to oil discharge?
    Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,179
    Re: 4.6L 32 valve water in oil
    "Other engines" is the wrong forum. Moved to Northstar. PLEASE read the descriptive text in each forum title - it tells you what gets posted where.
    What year is the car ? It makes a difference in intake manifold configuration and ignition coil arrangement. No idea of "plug caps" under the intake manifold. Exhaust puff out of the coolant reservoir cap ???
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    A photo will be necessary to determine what caps your question concerns. But from the sounds of it an external oil leak is the least of your engine concerns.
    Vernon
    68
    82,048
    PLEASE, update your profile to show the model and year.
    We need a lot more info. I am as confused as everyone else.
    Mar 2013
    64
    Quote Originally Posted by Submariner409 View Post
    can you give me a link to the right forum?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the thread has already been moved to the correct forum
    got any pictures ?
  9. Remove Advertisements
