Tappets or Rocker Followers - Two Different Head Designs??? - Page 2
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Northstar Engines and System Technical Discussion Discussion, Tappets or Rocker Followers - Two Different Head Designs??? in Cadillac Engine Technical Discussion; Flat tappet NS motors use lash caps? Are they solid? They are just a spacer between cam lobe and valve ...
  1. #16
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 96 STS, 140k
    Aug 2007
    mpls mn
    2,472
    Flat tappet NS motors use lash caps? Are they solid? They are just a spacer between cam lobe and valve stem? I have pulled out a few from junkyard cars where the cams were gone. It looks like a heavy duty cup? I never really inspected them closely or turned them over. It seems solid to me? No hydraulic adjustment?
  2. #17
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a big stereo
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    74
    43,119
    Re: Tappets or Rocker Followers - Two Different Head Designs???
    They're hydraulic cam followers - a modern version of lash caps. Take a hard look at one - there's one or more oil supply holes drilled in the groove - the bucket rides in the head bore, and full pressure oil is supplied to the bucket by internal oil passages in the head. The follower is actually about 3 pieces - outer bucket, inner hydraulic valve actuator, check valve.
    FWIW - In the older, solid cap style of follower there was a hardened steel disc between the follower and cam tip. These discs came in about 20 thicknesses. To set valve lash you warmed up the engine, shut down and removed the cam covers. Then hand-turned the engine, miking the individual valve clearances with a feeler gauge. If a valve was too tight or too loose, you removed the cam(s), miked the disc insert, added or subtracted the necessary lash correction, and inserted a new disc of the proper thickness. (Now do that on a Ferrari V-12.)
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
