2002 STS Bottom end repaired early on.........questions
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, 2002 STS Bottom end repaired early on.........questions in Cadillac Engine Discussion; I found out the engine in my STS apparently had some kind of bottom end problem early in it's life ...
    Caddydrummer67's Avatar
    Caddydrummer67 is offline Cadillac Owners Fanatic
    Automobile(s): '02 ETC 32,000 miles 2002 F55 STS 78,000 miles
    Jun 2012
    Black Hills of SD
    239
    I found out the engine in my STS apparently had some kind of bottom end problem early in it's life and was repaired under warranty. Bad piston or something. My question is, if it was taken apart at a dealer under warranty, what would they have likely done to the heads/block on re-assembly. Time serts?...........would they have just bolted it back together with no work on the threads? Any one know of a TSB regarding this? Maybe Chris can answer this.
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    Re: 2002 STS Bottom end repaired early on.........questions
    Based on my experience GM would only agree to pay for repairs to any threads found or damaged during repairs. They wouldn't do them all just to be nice. If enough of the holes stripped upon dis-assembly they would have replaced the engine as a defect.
    Vernon
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,573
    The 2002 GM/Cadillac service manual has a chapter on specific types of thread repair, including cylinder block head bolt hole repair using inserts - but it does not say that every bolt hole must be inserted during normal or warranty repairs.
  5. #4
    68
    81,755
    Yup, under warranty they only fix what's broken. No PM. When it's on YOUR dime, they'll do all 20.
  6. #5
    Sep 2011
    46
    413
    I thought about this after I posted. I didn't also make clear that my opinion is also based on the fact that the bottom end was already condemned. That's why I think if they started finding too much wrong, as in many stripped holes along with the bottom end work, they would have just totalled it and stuck in a warranty engine. It's all about costs, not spending more just to fix every last engine they ever built. To them it's just a commodity, they don't feel obligated to fix it all when they have a most cost efficient option that gets it done with a known good a lot faster.
    Vernon
  7. #6
    Jun 2012
    Black Hills of SD
    239
    The exact wording in the system the dealer accessed (VIS, or whatever database they use now) said Piston and or Rings both banks?????
    So, what?.........there were bad rings/pistons on both banks............I find that highly unlikely.............I suppose not impossible though.
    Happened at approx 36,000 miles......not as early on as I thought. Anyone ever heard of this?
    If they had replaced the engine, I would think that database would say as much.
    So the question is did they cut corners on the job and compromise the integrity of the head gaskets/block threads?
    I know the name of the dealer where it was done, hopefully they will give me additional info on the repair. It was only 5 years ago.
    I guess I'll find out when the car starts overheating...........or doesn't.
  8. #7
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,179
    Ah, there was a TSB for post-2000 N* engines... if they consumed excessive oil within the warranty period the dealer would update the rings to the newer style. I know it was 2000 model year, probably through 2002 but I'm not sure. That TSB was in one of the oil consumption threads here in this section.
  9. #8
    Sep 2011
    46
    413
    Caddydrummer since we have to guess here's mine: They removed all the head bolts without a hitch (very low mileage then) and so they just put new ones in, torqued them to spec, and now you're still driving it without a problem just as GM engineered to to be. It's only when corrosion or bad metal enters the equation that it's a guarantee you'll have pulled threads. Remember it's not a guaranteed failure, even if the odds are it will.
    Vernon
  10. Remove Advertisements
